Pics of removing dash to get to Speedo-Cable?
I have that horrible noise that comes from the Speedo cable. I want to lube it, but a little hesitant to pull the dash apart since I have never done it on a Toyota before. Does anyone have any pics, or a write up on how to get to the speedo cable? Thanks.
Its really easy to pull the guage out in the dash if that is what you are talking about... There are only a couple of screws you have to deal with and then just unhook the wiring connectors... The only picture I have is on my 92 after I already had the guage out and I could post that if you think it would help but otherwise I say just jump in and pull the screws...
Less than 16 screws and then you just pull the cable off the back of the gauge cluster. Taking it out isn't the hard part, getting the speedo cable is the part that requires patience...just a tight spot and a fit that only goes one way. Nothing to it as I've done it a half dozen times now. Make sure you hold your mouth right when you do it.
09-04-2015 09:27 AM
Esibnitsud
07-30-2015 08:21 PM
highonpottery
7
07-18-2015 02:48 PM
