| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
pics needed of 3rd gen. 3"susp. and 2" body
#2 (permalink) | |
Quote:
Case closed!
__________________
Brian 1998 4Runner SR5 |
#3 (permalink) |
you don't need that much for 305's. they're 33" in diameter. all you need is a 2" suspension lift in the front to clear them. for 315's (35's), then you'll need the same 2" of lift in the front and a 1" body lift.
1. 1.5" of suspension lift and 1" body lift in this pic with 305/70-16's on 16x8 wheels and 4.5" of backspacing. no rubbing after trimming the pinch weld on the firewall. ![]() 2. this one has an OME suspension. 2.0" up front and 3.5" in the rear with a 2" body lift. those are 285/75-16's on 16x8 wheels and 4.25" of backspacing. ![]() 3. this one has 2.0" of front suspension lift with a 1" body lift. the firewall has been clearanced along with the upper A-arms so the 315's would fit. those two things are a must to run 315's without any rubbing.
#4 (permalink) |
Do I need to regear for 33's? And if the answer is no, what about 35's?
__________________
1998 4Runner SR5 TJM T15 BFG MT IPF CB OME SW OMFG CDROM ABS MDF WTF Umm... yeah! |
#5 (permalink) | |
Quote:
Eventaully I want to regear. |
#6 (permalink) | |
Quote:
__________________
____________ Edwin 1999 SR5 4unner |
#7 (permalink) |
Here is mine for now...different stages can be found here.
http://www.yotatech.com/showthread.php?t=71997 I currently have about 4-5 inches all around total....soon to be close to 7.5 inches/8 inches total. ![]()
__________________
1999 Toyota 4Runner limited 4x4,BFG's 285/75/16's. Land Cruiser wheels. 2inch 4crawler BL, Factory Locker, 4inch ProComp front IFS lift, front LC coils on the rear with LC shocks. Original owner.18-19-mpg highway. 2007 Dodge Mega Cab 4x4, Mineral Gray, 5.9L Cummins. SMARTY JR, Mufler delete, Silencer ring MIA, SIRIUS. PICTURES OF RIGS http://community.webshots.com/user/roofgoof Owner of 1970 Pontiac GTO JUDGE Last edited by ROOFGOOF; 10-03-2006 at 10:42 AM. |
#8 (permalink) |
2.5~3" susp, 1.5 BL. before and after.
![]() ![]() not much noticable difference...on a black truck anyway haha. 305 is the same height as the 285's just wider so no added clearance needed. when i did susp and no BL i rubbed only on plastic trim parts (flare and running board@ full lock. i have FZJ80 wheels which are 4.5 or 4.75" backspacing.. what gears do you have now? ive got 4.30's and felt a power loss goin to 285's. im over that now, but wish i had lower gears on the trail. same would apply for 305's. if youre wanting 315's its alot more work. wouldnt go higher (numerically lower) than 4.56's and would definitely need alot more clearancing either via cutting, or bigger body lift..of which i wouldnt do the latter...
__________________
sonny ------- 1998 4Runner LTD. Fabtech CO fronts, OME/Pro Comp rears, SS rear links, Revtek diff drop, oem elocker, ARB RD90, 4.88's, 315/75/16 MT/R's on FZJ-80's, Trail Gear sliders, ARB Prado Bar, 1.5" 4Crawler BL, Tundra Brakes, wabfab disco's, IPF's...satoshi'd deckplated & ISR'd. SOLD!!! new ride: 1997 FZJ80. ome/arb/bfg/etc. when clinton lied..nobody died |
#9 (permalink) |
![]() 2.5" OMEs in rear, 2" spacers in front, 1" BL and 305/70/16's. |
#10 (permalink) |
Looks like 305's are the way to go. It looks alot better than the skinny 285's
#11 (permalink) |
Yeah. I have 285's now. I want a little wider and maybe taller If I can get away with it!
#12 (permalink) |
295's would be another good choice. 295/75-16's are ~34" tall and approximatley 11.5" wide compared to the ~33" height 11" width of the 285's and the ~33" height and 12" width of the 305's. i know Nitto makes a Terra Grappler in that size...
#14 (permalink) |
I like that Idea. I'll have to check on the BFG at's and see what kind of deal I can get. Now hopefully I can sell my 285's to offset some of the cost of doing this.LOL
Bryan |
#15 (permalink) |
Before with 3" in front and OME's in rear
![]() After with 3" front and LC coils in rear + 2" body lift
__________________
"Live and learn, Die and forget it all" 1996 4Runner SR5 V6 4x4 Lifted, Locked, and Armored
#16 (permalink) |
i put on 295's and have a 1" body lift and have rubbing issues on my rear bumper and barely on the pinch weld in the front.
__________________
- Kyle Former Owner of - 1996 Sunfire Red Metallic 4Runner Limited updated 10/31/06 OEM/TRD Lift Kit #1 from Sonoran Steel with 1 Top-out spacer - Lexus GX470 rims - 295/70r17 Nitto Terra Grapplers Yukon 4.88's, E-Locked Rear, Waiting to blow up front diff #2 Last edited by KyleT; 10-03-2006 at 02:42 PM. |
#17 (permalink) |
__________________
- Kyle Former Owner of - 1996 Sunfire Red Metallic 4Runner Limited updated 10/31/06 OEM/TRD Lift Kit #1 from Sonoran Steel with 1 Top-out spacer - Lexus GX470 rims - 295/70r17 Nitto Terra Grapplers Yukon 4.88's, E-Locked Rear, Waiting to blow up front diff #2 |
#18 (permalink) |
Harrison,Does your truck feell like it has alot of bodyroll with the 285's on it?
I like the stance of kyles rig alot. The Lexus rims are 4" backspacing right? |
#19 (permalink) |
I can feel the body roll, but it doesn't bother me that much. I am a very easy driver on the road and it handles fine off road with the stuff we have around South Carolina. I am definately going for some larger/wider tires in the near future.
__________________
#20 (permalink) |
bamecham, What all is involved in clearancing the firewall for the 315's. I already have total chaos upper arms and AR Teflon rims w/4.5" back spacing. I am leaning towards maybe the Pro-comp extreme all-terrains(Kind of a mix between the muds and regular all-terrains). I also noticed the runner in the 3rd pic only had a 1" body lift. Would a 2" mean less to worry about on the firewall?
Thanks,Bryan Last edited by 4runnin2; 10-03-2006 at 06:50 PM. |
#21 (permalink) |
Please show pics of how much pinch weld trimming was required to fit 33x12.5's with only a 2" lift... I'm not debating whether it would work or not because with enough trimming, anything is possible... Just want to know the extent of how much cutting is involved...
__________________
2007 Tacoma Double Cab 4x4 TRD Sport 6speed
Pro Comp 6" - Bilstein 5100 front 18x9 Moto Metal 951B - 325/60/18 NTG Pro Comp Skid - Lund Grill Cover 17x10 Weld EVO Velociti 6 *soon |
#22 (permalink) |
I cut my pinchweld back almost even w/ the firewall and don't have any clearance issues w/ 285's and 2" lift. I will try to get some pics for you when I get my truck back.(Tomorrow or Thursday)
#23 (permalink) |
I don't have any rubbing with the Donahoes in the front and 285/75/16's Tires. It may be because I have aftermarket rims though?
#24 (permalink) |
Not sure if you are still in the market for pics, but here is my rig with 3" suspension and 2" body.
My front end clearance after some trimming with a Dremel (before 2" BL): ![]() ![]() And after shaving the lower valence (before 2" BL): ![]() Body lift install... the left side (of the pic) is finished, now onto the right: ![]() All finished ![]() All dressed up and ready to roll... ![]() ![]() ![]()
__________________
DON'T SHOOT! I'm an involuntary traitor to the Toyota world. This WAS my Toyota... a loaded 1998 4Runner SR5 2wd Check out my Sound Domain web page to see it in all it's glory! |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| JDM 3rd gen "Hilux Surf" emblem *PICS* | purplehazek4 | The Classifieds GraveYard | 1 | 04-28-2006 06:07 PM |
| Explain this lift - 4Runner with 6" susp, 3" body | slick858 | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 02-21-2006 01:11 PM |
| 3rd Gen rolling on 315/75/16: 2" Suspension lift, 1" Body lift | sschaefer3 | 95.5-2004 Tacomas & 96-2002 4Runners | 114 | 01-02-2005 05:12 AM |
| Anyone got pics of 3rd gen ltd "Dune/Silver"? | yoda-g2 | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 02-16-2004 10:06 AM |
| 4.5" susp and 3" body lift on Tundra | YoTRacer158 | 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 | 1 | 11-11-2003 12:55 PM |
