PICS from my lift install
Old 04-25-2004, 06:28 PM
snoozer's Avatar
Hey everyone, here are the pics from my lift install.
More pics here
The shop with Blake's 4Runner in the foreground:
Me with spacer installed on front coil (Blake did all the hard work):
Spacer installed (w/ me installing the diff drop):
OME N86 and Downey coil:
Another angle:
Old 04-25-2004, 06:37 PM
snoozer's Avatar
And a few pics from wheelin' the next day. See the above link for full size images.
Never disconnect the top of an endlink and not the bottom. I couldn't get the pin out of the bottom of the disco and I was so excited to be wheeling with my new setup, I left it like that. This is what happens:
Old 04-25-2004, 06:38 PM
shazaam's Avatar
looks good man ..
Old 04-25-2004, 06:45 PM
Designsbyme's Avatar
Yee haw you finally got it up. There may be some guys going out this weekend to 360 if you're open. I'll be driving my truck home tomorrow. I can't wait. I also got my suspension done too. Hope to see you this weekend. I'll bring a jack and some fix-a-flat this time.
Old 04-25-2004, 06:50 PM
CTB
CTB's Avatar
Just a word of advice...
avoid using Fix-a-Flat if possible. That stuff is terrible and can eat up the inside of your tires. Not to mention, your tire will be out of balance, and it is a pain to get all cleaned up.
Old 04-25-2004, 06:53 PM
It was a joke. You should have seen his tire. Fix a flat would have done nothing. He had to get the entire umm uhh tire replaced.
Old 04-25-2004, 06:54 PM
tombothetominator's Avatar
agree
I wholeheartedly with the above statement. Fix-a-flat = horrible
Old 04-25-2004, 07:05 PM
PoBoy's Avatar
Can this thing turn?
Old 04-25-2004, 07:07 PM
Scofco's Avatar
Congrats on the new setup mate!
Old 04-25-2004, 07:08 PM
Fink's Avatar
Yeah I was gonna say, he must not be able hit very big bumps with those tires stuffed under that thing.
Fink
Scofco's Avatar
Nothing a hammer and some muscle can't take care of
Old 04-25-2004, 07:11 PM
Scofco's Avatar
You must be pissed putting a hole in your brand new Destination MT's
That sucks dude.
Old 04-25-2004, 07:27 PM
I was just posing with those tires next to mine.
Old 04-25-2004, 07:29 PM
Scofco's Avatar
Duh.
Old 04-26-2004, 05:07 AM
waskillywabbit's Avatar
Talking Uh oh
Just cut off the top bolt from the rod end, drill out the rod end and put in another carriage bolt and you should be good to go. I'd also back off that bolt next to the rod end so you can more easily pull the latch pin next time! Quick discos aren't worth much if they aren't quick and you don't use them! Luckily you didn't tear up a CV with that bent bolt.
Looks good!
Old 04-26-2004, 07:21 AM
snoozer's Avatar
I removed the endlink right then. It was much easier to whack the pin out with the wheel off. Only the threaded rod and stainless sleeve were bent. I unscrewed the heim and the nuts from it and replaced the rod.
Blake, glad to hear your truck is functional again. What happened with the engine? I don't know if I can make it out this weekend. I've got finals this week and next and have been really busy at work, hence the delay in posting. I'll let you know closer to time.
Old 04-26-2004, 08:35 AM
CSU$4-WhEEleR's Avatar
Correct me if im wrong but i think thats a 2 inch body lift with 33-12.50's. If thats the case than i have seen this set up on a few runners around town and it seems to work . Dont quote me though as i have never actually driven one. Cant imagine it does much for off road but for tooling around town i suppose it makes for a statement.
Old 04-26-2004, 11:27 AM
Scofco's Avatar
Old 04-26-2004, 11:40 AM
lee
lee's Avatar
those tires are sitting NEXT TO that runner -- they are not ON the runner. its just a joke.
Old 04-26-2004, 11:44 AM
lee
lee's Avatar
also, i just noticed by your pics that someone out there paid for an h2 and is actually taking it offroad!
wow.
Quick Reply: PICS from my lift install
