Pics for the guys who wanted them
While I was taking pictures of the engine I just snapped a couple of the truck top..
I used my old valve cover (the inside was alot cleaner from the other newer one)
I also was going to clean it up, but I decided not to. It's going to just get dirty agian plus its not no show truck.
Everything on the engine works perfect, the timing it perfect the valves might need to be adjusted again, after twice yesterday. The only thing is that it has a vacuum leak somewhere (a little one).
Thanks,
Mario
Thanks,
Mario
looks good...have you thought about an intake/battery swap? Reduces heat soak by not running the intake over the hot radiator...Yamaha+toyota=fun did this and I could notice a difference from the passenger seat. Costs not even $10...just need a longer battery cable and a 90* elbow and two rubber hose clamps to get from the TB to the airbox.
Never even crossed my mind but I will look into it, thanks.
I wish I had a picture of the truck when I bought it, I rebuilt the front end.
Thanks,
Mario
Thanks,
Mario
Ya the front was wrecked, the frame was pulled, after that I replaced the windshield, front bumber, grille, radiator, all the lights, in the one pic you can see my off color spray paint I used after I sanded the rust off and to my best straigten the fender, its on the other one to. Also the truck is a 92 but has the 89-91 grille and bumber (used and way cheaper than new)
Mario
Mario
6th Gear
19
12-10-2019 07:31 AM
