Pics of front wheel bearing/spindle assm
Old 04-16-2007, 06:33 AM
colsoncj's Avatar
Does anyone have any pics of an assembled, partially dissassembled, or fully disassembled front wheel bearing/hub/spindle assembly. Apparently the bearing is a press onto the spindle, and I'm tryin to get a feel for how everything is laid out. (I havent crawled under there and looked yet).
I have a front end vibration that is either a wheel bearing or a bad u-joint/u-joint that needs grease. It is speed specific and is most noticable at certain speeds (40ish and 65ish) which to me seems driveline like, but it feels like a wheel bearing. There is also a slight noise with the vibration, but nothing to write home about (I'm the only one that can hear it). I'm going to crawl under it, give everything I can find a good lubin, check play in the wheels and see how it goes. I'd welcome any comments.
colsoncj is offline
Old 04-16-2007, 07:59 AM
BajaRunner's Avatar
Here's one:
http://www.deserted1.com/FSM/Repair_...4wdpr/comp.pdf
I know that the front wheel bearings are sealed. This means you need to buy a new bearing and have it pressed in. You cannot re-lube it!
As for the rears, I think you are able to re-lube them. But, dont quote me on that.
Have you tried lubing the driveshaft? That seems to be a common problem.
I hear you on odd noises, it really gets under my skin too. I am ALWAYS the only one in the car to hear it. I turn down the music, open my windows, and stick my head out while going over bumps at various speeds. People look at me like Im looney.
BajaRunner is offline
Old 04-16-2007, 09:26 AM
colsoncj's Avatar
Ya I knew they were a sealed, and a pressed type... Fun Fun. The driveshaft and anything else that has a zerk is getting the attention first, then I'm going to play it from there.
Also, am I looking at that pic right that the upper BJ is held in by the snap ring, or is a press fit holding it in?
EDIT: also if the rears are anything like a 1st or 2nd gen 4Runner they are a sealed, pressed type as well.
colsoncj is offline
Old 04-16-2007, 09:43 AM
BajaRunner's Avatar
The upper ball joint is held in by a castle nut and pressed in there nice and well. There is also a snap ring of somesort below the boot. I needed a special tool to get it out. I used a gear puller and a tool from Total Chaos to pull them apart. :/
Old 04-17-2007, 05:30 AM
colsoncj's Avatar
Well I got around to greasing both driveshafts... But didnt get to pulling a wheel and checking play. Drove it this morning and still have a vibe.... I guess the next step is pulling a wheel.
colsoncj is offline
Old 04-17-2007, 08:12 AM
BajaRunner's Avatar
Well just jack up the front, and strattle that wheel. Push/pull it and see if it has excessive play first !!
Dude, I dont know. It might be something in your suspension? Seems like people having wheel bearing issues/ball joint issues are pretty slim around here.
Old 04-17-2007, 01:32 PM
colsoncj's Avatar
It does seem uncommon for the wheel bearings to go given the lack of comments on the forum. As soon as I get a wheel off and do some diggin around, I'll post if I find anything.
colsoncj is offline
Old 03-01-2009, 01:03 PM
jmcgowan's Avatar
Originally Posted by colsoncj
Does anyone have any pics of an assembled, partially dissassembled, or fully disassembled front wheel bearing/hub/spindle assembly. I'd welcome any comments.
Try this site
http://www.toyodiy.com/parts/
jmcgowan is offline
Old 03-01-2009, 02:54 PM
colsoncj's Avatar
Thanks for the help, but the truck has been sold for over a year...
colsoncj is offline
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
Yotoder865
07-09-2015 07:51 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Pics of front wheel bearing/spindle assm
