pic of parking brake pivots
Senior Member
Anyone have a pic/diagram of the parking brake pivots? Mine are corroded and thus stick from time to time. This is one of those times. I'd like to see if I can free up the parking brake rather than paying to have it done.
On a side note... should my drums end up being stuck, anyone have info (size/tread etc.) about the bolt used here to remove them?
Thanks for the help. I suspect I could figure out most of this, but I hate getting my truck up on stands and getting 3 hours into a job just to find out that for whatever reason I can't do the job.
Originally Posted by shiftless89
Its easy to do, start at the drum and follow the steel cable, lubing each pivot as you go forward, repeat for other side
Jackson, here's a few pics for you (and you were right, the technical name for them is bellcranks!):
Senior Member
Cool - thanks. THat's what I was looking for. I knew I had seen it before, but couldn't find the thread. Is it just me, or does that bell crank look like it's not "inside" the drum. Perhaps I can get at it by just takign off the wheel and crawling up in/behind there...
The pics are from an online manual.
Senior Member
I got under my truck last night and was pleasantly surprised. I pulled the boot back away from the pivot point (boots were filled with debris/dust/garbage - should they be packed with grease?), sprayed about 1/3 of a can of PB in there then wacked on the bell crank with a hammer. It was enough to release the parking break, which was all I was after. If I have more time I might try to get them loosened up so the parking brake becomes useable again, but at this stage of the game, it's not that big of a deal.
Thanks again fro the pics Jamie.
09-04-2015 09:27 AM
94 Newbie
08-06-2015 10:33 AM
terminator
07-27-2015 07:13 PM
CanRunner
07-20-2015 01:29 PM
