PIAA light idea...!
Old 05-09-2006, 07:38 PM
fireteacher's Avatar
PIAA light idea...!
anybody seen ir tried this one yet? not gonna get a bumper/brushguard so i was thinking of doing this.
pro's?
cons?
concerns?
like/dislike?
please..please!!!!
Old 05-09-2006, 07:39 PM
Elton's Avatar
i think it would look awesome right there nice and clean
holly ˟˟˟˟˟ batman, thats a huge pic.....sorry guys!
mods, i am at a loss here, i cant figure out how to resize pic and i do not have a editing program other the PAINT! if you wish , ill pull it down.
Old 05-09-2006, 07:42 PM
quick, how to resize damn pic! photobucket is what i use but made it huge this time!
Old 05-09-2006, 07:43 PM
lr9788's Avatar
very cool ive considered that same thing, if you end up doing it post pics and how you feel about them
Old 05-09-2006, 07:52 PM
JHupp's Avatar
Are you just mounting them to the stock plastic valence? If so, they would wobble like crazy, I would try to find something behind all that, that's solid.
Old 05-09-2006, 07:55 PM
noted
Old 05-09-2006, 08:06 PM
Cebby's Avatar
win xp image resizer - PLEASE!!
Old 05-09-2006, 08:08 PM
Skrillah's Avatar
Killer idea but I would tend to agree with the above statement! I'll be interested to see if you can get it to work, keep us posted!
Old 05-09-2006, 08:10 PM
lr9788's Avatar
have you measured that space?? what size light could you fit there
size wise for the light, do you think 6 inch will be ok there?
Old 05-09-2006, 08:11 PM
just got bored watching bonds choke...so i tried it out and will measure it tomorrow.
Old 05-09-2006, 08:26 PM
BajaRunner's Avatar
Hey --
Dont mount them to the plastic, its too flimsy.
Instead, just turn them upsidedown and mount to the underpart of the bumper.
My OEM ones are mounted there, but, you'll need to trim off that plastic. It would work well.
Old 05-09-2006, 08:49 PM
Merlin's Avatar
+1 to SC4Runner - plastic is going to be flimsy.
How I mounted my PIAA lights where you have indicated was to use some homemade brackets. The holes in the bumper (at least on my 98) aren't near where you want the lights to be, so we bent up some metal and made some brackets to mount the PIAAs to. We also had to cut the grill slats (small keyhole saw, small hacksaw, dremel, even hot butterknife will work) to fit the lights.
PIAA lights are expensive, so we also used some blue LocTite to hold them securely.
I'm not sure about the model you are thinking about, but some foglight lenses have an up and down position. If this method of mounting is upside down, you may have to invert the lens to maintain proper orientation. The lenses should have some sort of top and bottom markings if this is the case. Also - you may want to recess them so they do not protrude beyond the front edge of the bumper. PIAA lenses are very expensive and hard to come across, so you don't want to hit them on anything and have them crack on you.
Hope this helps,
Merlin
Old 05-09-2006, 08:52 PM
anything helps!
Old 05-09-2006, 09:18 PM
lr9788's Avatar
merlin, you have any pictures of how yours mount?
Old 05-09-2006, 11:46 PM
mdh
mdh's Avatar
I mounted a set of piaa 960s in that area. To improve stability and get them in the right position I got a piece of angle aluminum with holes at home depot and mounted it to the end of the frame rails. There were some very convienent holes at the ends of the rails. All I had to do was cut some plastic to get them in the valence and mount them right to the aluminum. some round lights would be better since the fogs on the 960s are useless.
ashersullivan88yota
01-18-2022 05:37 PM
4.34runner88
08-11-2018 10:44 AM
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
Odin
07-15-2015 09:28 PM
Quick Reply: PIAA light idea...!
