Performed spacer lift, both inner CV joints threw up!!!!! What to do...
Old 05-12-2009, 11:10 AM
jvh4513's Avatar
Thumbs down Performed spacer lift, both inner CV joints threw up!!!!! What to do...
I own a 96' 4runner with a 3" 4crawler bodylift and 3" OME coil/shock setup. I finally got around to installing my Daystar 1.25" top plate spacers and just about a week later BOTH my driver's and passenger's side inner CV joint boots tore and "threw up" some grease.
Whats the recommendation? Do I simply clean them, repack them with grease and replace the boots? Go with new CV joints since I probably have to take both CV joints out? Any ideas guys that have had to deal with this problemo before..?
Old 05-12-2009, 11:57 AM
Doddy's Avatar
You should get a diff drop kit and take out the 1.25" daystar soacer if you already have the 3" OME setup up front. Your going to keep on blowin boots if you keep runnin that setup, the 96-02 Runners just can't take that much lift or you over stress the CV's. Re-pack the CV's and take off the spacer.
Old 05-12-2009, 12:29 PM
scuba's Avatar
Pull spacers.
Or Install manual hubs.
Old 05-12-2009, 12:59 PM
OSU4Runner's Avatar
I'm in the same boat as you, except I just did the SS 1.2 lift....with the diff drop and both my inners tore. I think they tore cuz they were old as hell....had alot of miles on them already....I'm just gonna replace both CV's instead of repacking the boots, since I'll have them off anyway.....I did find this website that sells high angle inner CV boots, they are towards the bottom of the page....I'm going to order those as well....hopefully they'll alleviate some stress. http://www.offroadsolutions.com/96-02_4runner.html
Old 05-12-2009, 01:00 PM
OSU4Runner's Avatar
Originally Posted by scuba
Pull spacers.
How hard is the manual hub swap to do? I've been thinking about it...I know you need the hubs from an old taco, but what other parts? Are they different CV's as well?
Old 05-12-2009, 01:28 PM
sdsurfer's Avatar
truck at shop now. installing "cheap 2.5 spacer lift all the way around with diff drop. cv are super old i hope all holds up
Old 05-12-2009, 01:31 PM
scuba's Avatar
http://www.parksoffroad.com/tacomamo.../orsmanhub.htm
Old 05-12-2009, 01:39 PM
Ron Helmuth's Avatar
pretty sure Off Road Solutions is out of business
hope I am wrong but I believe Off Road Solutions folded about 3 months back
Old 05-12-2009, 01:41 PM
scuba's Avatar
They did in december, Dec. 18 IIRC.
umm, but it does say exactly what parts are needed.
Old 05-13-2009, 01:42 AM
OSU4Runner's Avatar
Wow...that sucks......they should take their website down!!
Old 05-13-2009, 06:30 AM
jvh4513's Avatar
I have the diff drop kit installed already...
I'm guessin the OME gave me 1.25-1.5" lift up front, so with the 1.25" Daystar spacer the front lift shouldn't be past 3". If you factor in the diff drop kit it should only be maybe 2" higher from stock?
What brand of CV's you using?
Old 05-13-2009, 09:11 AM
scuba's Avatar
I believe you can still order some of their items that they couldnt get rid of before they closed.
And no, They shouldnt take their website down, Its full of good info.
Old 05-13-2009, 09:56 AM
UKMyers's Avatar
Manual hubs are really spendy for 96 and up rigs scuba.
When I lifted my Tundra my boots started to leak. I went to Napa, showed them my old clamp and they gave me real ones that you need a special pair of pliers to clamp on. The pliers are cheap and are a good thing to have in your tool box. For less than 20 bucks I replaced all 4 clamps and got a real good squeeze on them and have not had a lick of trouble since. The stock clamps only have one notch and they suck. Even a zip tie works better than the stock ones. Even if you end up replacing your boots entirely if they ripped I would still put an aftermarket clamp on there.
Old 05-13-2009, 10:43 AM
scuba's Avatar
Yes Joey, I have researched it, Even though I dont need it cause my Taco already has them
But I was just listing options...
Old 05-13-2009, 11:07 AM
jvh4513's Avatar
Anyone heard of plastic boots you can clamp over from NAPA without taking anything apart?
Old 05-13-2009, 11:27 AM
Godzilla's Avatar
Are you talking about putting a boot over the existing CV boot?
Old 05-13-2009, 02:05 PM
jvh4513's Avatar
Haha yeah..
Old 05-13-2009, 02:25 PM
Godzilla's Avatar
There is not point on doing this. All you are doing is catching the grease that is spitting from the real boot, which will leave your cv's dry.
Did the boots actually tear or just leaking past the clamps?
Old 05-13-2009, 02:34 PM
Dare44's Avatar
I have found that autozone's cv's are much stronger and dont leak like the stock or napa ones. and they come with a life time warrenty. I havent had to use it yet tho.
Old 05-14-2009, 06:36 AM
jvh4513's Avatar
How long (miles/time) you had them on.. as compared to the stock ones? Much offroad use?
Blamalam
03-12-2022 07:34 AM
09-04-2015 09:27 AM
4Runnin2000
07-29-2015 06:09 PM
coffey50
07-28-2015 10:55 AM
ksmudrunner99
07-21-2015 05:33 AM
Quick Reply: Performed spacer lift, both inner CV joints threw up!!!!! What to do...
