Performance Products 1" lift coil springs... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-09-2003, 12:09 PM   #1 (permalink)
Andrey's Avatar
Send a message via ICQ to Andrey Send a message via AIM to Andrey
I have a quick question for those who have PP 1" lift coil springs installed.
I had mine for just over a month and within last week the rear springs started to develop a clicking noise every time I go over a bump or pull out of my driveway. I had a local shop install all 4 coils for me, so I might not be exactly sure about particular details of the install.
Before I take my 4Runner back to them, is clicking in the rear even normal with PP springs? What about passenger/driver side springs, is there a difference? Also, should they check anything in particular?
Thank you in advance,
-- Andrey
__________________
'01 4Runner SR5 - 4x4
- 1" lift PP springs, deckplate mod, amsoil air filter, optima battery, alum. skid plate, alum. tube steps
- Pioneer 8500MP, PhoenixGold Amp + Infinity Kappas, RockfordFosgate Amp (mono) + Audobahn 10" Sub
- Yakima roof rack, Silverstars, Black Pearl emblems, Wet Okole seat covers, Wood Trim
- TRD Supercharger, 7th inj. kit... weee heee!!!
Andrey is offline
Old 09-09-2003, 12:24 PM   #2 (permalink)
RTdawgs's Avatar
this wont help you out much, but i do know that they SHOULD NOT click
__________________
Ryan
New: 2008 4Runner Sport. Mild, not wild.
Old: 2000 4Runner 305s, Locker, TJM, Warn, Skids, Sliders, SC
RTdawgs is offline
Old 09-09-2003, 02:41 PM   #3 (permalink)
SLC Punk's Avatar
Send a message via AIM to SLC Punk Send a message via MSN to SLC Punk
I have never had a problem with it clicking.
I would take it back, maybe they forgot to tighten something!!
__________________
-Travis
1997 4Runner SR5 V6 4X4 Supercharged Desert Dune SOLD :(
1992 Celica All Trac (AWD-Turbo) #223 of 271 US spec for 1992 FOR SALE
2005 Tundra Double Cab Limited 4X4 2.5" lift 265/70R17 Dueler Revo's
4Runner and Celica Webpage
SLC Punk is offline
Old 09-09-2003, 04:39 PM   #4 (permalink)
Send a message via AIM to ravencr Send a message via Yahoo to ravencr
Check the rear panhard bar. Make sure the bolts are tight on either end, and the driver's side bolt has been inserted from the front to the back, and not the other way around. The nut should be towards the front of the vehicle.
Chris
ravencr is offline
Old 09-09-2003, 06:18 PM   #5 (permalink)
mine do not click.
bob
Bob_98SR5 is offline
Old 09-09-2003, 07:33 PM   #6 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
Mine are 2G in the rear, but no clicking. I've heard that they will squeek if some plastic piece is left out of the coil bucket - not sure if this applies to your situation, but I thought I'd toss it out there...
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 09-09-2003, 07:59 PM   #7 (permalink)
ALBPM's Avatar
No clicking here after almost a year.
Check your shocks too and make sure everything is tight.
__________________
2002 SR5 4x4, Dorado Gold
Suspension:
Front: PP coils/Bilsteins/RevTek Diff Drop.
Rear: Downey 3.5" coils/Bilsteins.
Tires: 265/75/16 D Bridgestone REVOS
The Rest:
I.S.R. Mod, Elbow Modified, Amsoil air filter, ARB Bumper and A pair of Hellas.
A whole bunch of other accessories.
Topped of with Zaino's Polish.
ALBPM is offline
Old 09-09-2003, 08:38 PM   #8 (permalink)
azrain's Avatar
Loose upper shock mounts (nuts loose on shock mount stud). The mount bushings on the shock stud should bulge ever so slightly. 14mm deep wall socket, small hands and patience...
You're welcome to swing by the house and we'll take a look.
I wrote several long dissertations on PP springs and the noises they make with air bags and Billies. Dependent on the situation and the set up, they are either the best spring you have ever used or they totally suck. My experience was the latter.
Mike
azrain is offline
Old 09-10-2003, 11:52 AM   #9 (permalink)
Andrey's Avatar
Quote:
Chris
Thanks, that was it! Looks like that panhard bolt became very loose, and that's exactly was causing the clicking noise. Tightening the nut solved the problem!
But next time I'll be installing all my upgrades myself. It might take longer, but it will be a very good learning experience and I'm pretty sure with everyone here at Yotatech I'll never get lost.
Thanks again,
-- Andrey
__________________
Andrey is offline
Old 09-10-2003, 11:59 AM   #10 (permalink)
Andrey,
I've never worked on a car in my entire life until I bought my 4runner and started reading up on everything here at Yotatech. Everyone on this board have been such a huge help to me, so right now I'm working on doing multiple writeups and threads of my current modifications so I can hopefully be as much help as all these other guys and gals have been to me.
I'm glad it worked out for you, because I experienced the same thing after I reversed the bolt on the driver's side of mine, not really thinking about it. After putting it back in the correct direction, it was gone.
Glad to hear the same happened for you,
Chris
ravencr is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Performance Products 1" springs and Bilsteins iceman601 95.5-2004 Tacomas & 96-2002 4Runners 42 09-08-2007 05:36 PM
285's and 1" performance products springs 1999runner 95.5-2004 Tacomas & 96-2002 4Runners 15 07-20-2006 10:58 AM
Performance Products 1" lift springs shiftMX 95.5-2004 Tacomas & 96-2002 4Runners 12 05-18-2004 05:34 PM
Performance Products 1" Lift springs---instructions? When? Bob_98SR5 95.5-2004 Tacomas & 96-2002 4Runners 16 04-01-2003 01:01 PM
Performance Products 1" Springs Installation ravencr 95.5-2004 Tacomas & 96-2002 4Runners 37 01-10-2003 04:56 AM
2009 InternetBrands, Inc.
