PCV valve replacement on the 22RE
Old 10-26-2003, 04:42 PM
JustAnotherJodieFE's Avatar
Ok, anyone have a clue about pulling this little bastard out of the valve cover? I've already busted the brittle gasket around it knowing that I'd replace it anyway. Now I still can't get the @%#&er out!
Old 10-26-2003, 08:22 PM
Krash's Avatar
I got a pair of pliers and sat the handle of a screw driver underneath for leverage.
Old 10-26-2003, 08:28 PM
kyle_22r's Avatar
yeah, use a pair of vise grips and clamp down on it good and firm. then stick a screwdriver underneath the handle and give it a good whack with your hand. the only hard part after that is getting the new grommet around the new valve and popping it in, it's a bit of a tight fit
Old 10-26-2003, 09:40 PM
nightsurfride's Avatar
Dude, I know exactly how you feel. I had the exact same situation with my 85 Yota and I just went to town on it. A piece did fall into the valve cover hole, but a pair of needle nose bailed me out. good luck.
Old 10-27-2003, 04:05 AM
I've been trying the vise-grip method, I'll work on it some more.
Old 10-27-2003, 08:58 AM
Krash's Avatar
I don't mean to hijack the thread but just a quick question. I've seen those mini cone filter looking breathers that some people have replaced the pcv valve with. Whats the advantage of doing this?
Old 05-15-2011, 07:46 PM
4x4climber's Avatar
extra oil lubrication all over your engine bay.... at least that was my experience with dunces doing it to their DSM's.
Old 05-16-2011, 01:13 AM
Gamma_Hugo's Avatar
take out the valve cover, get vise grips, stand on the valve cover and pull on it til it comes off. it came off in a flash, but it was a strain on my back though...
Old 05-16-2011, 02:31 AM
wyoming9's Avatar
Smile
I take it you have sprayed it good with your favorite brand of penetrating oil and let it soak. May as well replace the hose as well.
I trick for getting any rubber hoses grommets is to spray with silicone spray makes it so much easier
mskalmus
05-28-2017 07:51 AM
MMA_Alex
25
04-18-2017 05:07 AM
TURBOrunnerNM
07-22-2015 11:01 AM
bryan34w
07-06-2015 05:53 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: PCV valve replacement on the 22RE
