PCV valve location??????
Old 04-05-2003, 02:39 PM
Tomh4x4's Avatar
Ok I have a new pcv valve but can't find where its at any pictures or a description of where it is located would be greatly appreciated.
Thanks
Tom
Old 04-05-2003, 02:43 PM
Co-Founder/Administrator
Staff
Corey's Avatar
What are you driving?
There are some old posts here that show where they are on the 3.0 engine.
Old 04-05-2003, 03:41 PM
Tomh4x4's Avatar
ooppss hit to post a new thread. well its a 1991 3.0.
Sorry about that
Tom
Old 04-05-2003, 06:23 PM
DH6twinotter's Avatar
Hey,
The PCV is located on the passenger side valve cover. You will have to remove the intake plenum to get to it. I did this about 3 months ago. Not really that bad especially when you have Yotatech members to help you out like I did. When you know what to do, it's a fairly simple process.
Anyhow, if you follow the hose in the pic (the one with the green arrow on it) under the plenum, it will lead you to the PCV. I replaced my PCV hose while I was at it, so yours may not be as long as the one in the picture.
Sorry about the blury pic. It was dark out and I couldn't see where I was aiming the camera.
Well, hope that helps,
DH6twinotter
Old 04-06-2003, 11:58 AM
Tomh4x4's Avatar
Alright thanks.
Tom
Old 04-07-2003, 08:40 AM
"Cat-O-Leen"'s Avatar
The hose to my PVC valve just crumbled when I tried to take it off.
Plan on replacing the hose, and a rubber washer that holds the PVC valve in the valve cover.
This maintence repair really gave me an understanding of a lot of the vacuum hoses, cold start valve, and the pair reed valve.
I have a Haynes Manual that also helped with the disassembly
smthwsn357
12-04-2023 02:08 AM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
4x4-runner
08-30-2015 08:55 AM
ToyoToler
08-08-2015 08:43 AM
anniesball
07-29-2015 11:46 AM
Quick Reply: PCV valve location??????
