YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-05-2005, 11:43 AM   #1 (permalink)
pcv valve
I have a 4runner '95 ,V6,4WD ,and I have been trying to find where the pcv valve is located.Does anyone know about it?
Eneas28 is offline
Sponsored Links
To remove this ad, register today!
Old 03-05-2005, 11:49 AM   #2 (permalink)
ChickenLover's Avatar
It's located on the passenger side valve cover, under the plenum. It is possible to get to it without removing the plenum. However, you will need some long needle nose pliers, or some tiny friggin' hands. Good luck.
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k)
ChickenLover is offline
Old 03-05-2005, 11:49 AM   #3 (permalink)
TrevorR's Avatar
Passenger side valve cover closer to the firewall side, hard to see (and remove) but it can be done.
__________________
1993 4Runner 3.0L SR5 4x4
TrevorR is offline
Old 03-05-2005, 11:57 AM   #4 (permalink)
Thanks man!
Eneas28 is offline
Old 03-05-2005, 12:08 PM   #5 (permalink)
gwhayduke's Avatar
Take $28, go to your Toy dealer and laugh while they take an hour and a half to change it. It's worth every penny.
__________________
'99 4Runner SR5 4WD, 5-SPEED. Abzug's vehicle for urban expeditions, navigating flash floods and debris flows (try 12-15 inches of rain in one week). It always gets her home.
'95 4Runner LIMITED 4WD, 5-SPEED, over a quarter million on the original 3vze & headgaskets. TRD heavy duty clutch, TRD heavy duty flywheel, OME 900 springs and shocks. This old gal has gotten me out into the field, and back for 8 years, never failed to start or gotten stuck.
gwhayduke is offline
Old 03-05-2005, 12:59 PM   #6 (permalink)
TrevorR's Avatar
Yep gwhayduke is right just make sure they charge you the flat rate price, they will be there for ever and you pay something like $25.
__________________
TrevorR is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
PCV valve 2.7. Help! crazy_horse3030 95.5-2004 Tacomas & 96-2002 4Runners 4 03-01-2007 12:23 PM
Why only one PCV valve? ChickenLover 95.5-2004 Tacomas & 96-2002 4Runners 15 01-01-2005 07:10 AM
PCV Valve kevin444 Maintenance & Repair Archives 3 10-02-2004 05:53 PM
pcv valve ? bugalu Maintenance & Repair Archives 2 09-16-2003 06:37 PM
PCV Valve KraTOR 95.5-2004 Tacomas & 96-2002 4Runners 5 11-25-2002 02:00 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
