Parking Brake Adjustment
Old 06-21-2003, 10:21 AM
ts1
ts1's Avatar
In a 3rd gen Runner, do you adjust the parking brake using the nut near the handle or do you need to go under the truck? I tried the backing up maneuver while pulling the brake but it did not tighten the cable.
Old 06-21-2003, 11:47 AM
Bob_98SR5's Avatar
TS1,
Are you talking about the "length of the pull" of the ebrake itself? If so, its just a matter of undoing the center (arm rest) console. Take a look at my write up here:
http://www.4runners.org/articles/cupholder
Under Step 2, look at the first pic on the left. Its a top view of your ebrake. There are two opposing nuts, unscrew the top one a few turns, then screw the other one lower. Then screw the top one downwards. Your ebrake should take less "pull" to fully set.
The other thing I was thinking about is that if you have a lift, you might need an ebrake bracket. Tom and Steve installed one on mine when they put my PP 1" springs in. Ask them for more details.
Bob
Old 06-21-2003, 01:31 PM
ts1
ts1's Avatar
Bob,
I just looked up in the Haynes manual at the store that the 4Runner should have between 7-9 clicks of the handle for normal operation of the brake. I have 7 but I just thought it was loose. I think I will leave it for now. I know the nut you are talking about but how do you undo the center console to access the nut? I don't want to break any tabs.
I will read your writeup.
Thanks
Old 06-21-2003, 01:54 PM
Bob_98SR5's Avatar
TS1:
Easy to remove. First, take out all the crap out of your console storage area. Use a 12mm (or was it 10?) mm socket w/ an extension to remove the two bolts.
Up at the front of the console, unscrew the two philips head screws on either side of it. Lift up.
Bob
jashoeuh
11-26-2017 07:01 AM
terminator
07-27-2015 07:13 PM
Logz808
07-26-2015 07:09 AM
CanRunner
07-20-2015 01:29 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Parking Brake Adjustment
