P0171 with s/c, 7th ,and other stuff
Old 08-30-2005, 07:38 PM
3.4v6's Avatar
my taco threw this code twice in 3 weeks now. P0171 System too Lean (Bank 1) . at first i thought it just came on because my gas light was on causing low fuel pressure. but it came on again tonight. i am going to clean the MAF tomorrow but is there anything else i am missing?
thanks in advance
Old 08-30-2005, 07:58 PM
rimpainter.com's Avatar
From Mark...
Originally Posted by midiwall
A breakout of the codes is here:
https://www.yotatech.com/~corey/tech/dr_z_obd/dr_z.htm
From there, a P0171 is "system too lean, bank 1". "Bank 1" defines that this code is coming from the O2 sensor that's in front of the catalytic converter. (a similar code, P0174, would point to the O2 sensor after the cat) And yes, the O2 sensor is what the engine computer ("ECU") uses to compute the Air/Fuel Ratio.
There are a slew of codes (P0130 - P0167) that point to issues with the sensor itself, so that's not the place to start. I would guess that the sensor is "fine", though it may not be 100% perfect.
Anyway, what you've been told thus far is good info... The place to start here is with the MAF. The cleaning process is easy, and well documented here:
http://www.4x4wire.com/toyota/maint...ntenancep5.html
Past that, the air filter should also be replaced (or cleaned if it's a foam unit).
Try those two things first before replacing the O2 sensor, it's a fairly expensive part ($90) that will turn into a $160 visit to the dealer (parts plus labor).
Oh, you also asked for a favorite online parts dealer...
I've had great luck with these guys:
https://www.1sttoyotaparts.com/partscat.html
But, if you're thinking O2 sensor, then the best prices around are coming from a performance specialist ("Gadget") at URD USA:
http://www.urdusa.com/
Old 08-30-2005, 08:22 PM
3.4v6's Avatar
well i just cleaned the MAF and it did look a little bit dirty , next i think im going to ditch the k&n drop in filter and get something else. i just got the o2 sensor replaced about 6 months ago due to warranty issues so i hope that isnt it.
Old 08-31-2005, 07:10 AM
FilthyRich's Avatar
FWIW, I am not sure why, but my old K&N drop in caused CELs quite a bit. I have since replaced it with an Amsoil and have not had any problems.
Old 08-31-2005, 10:09 AM
MTL_4runner's Avatar
Ditto on the Amsoil, much better choice and no CEL issues unless you WAY over oil it after cleaning.
Old 09-01-2005, 08:49 AM
2000t4r's Avatar
I have not had any problems with my K&N filter. It has been on the truck for about 30K now.
ladybugRC
458
08-21-2020 10:41 AM
live4soccer7
05-11-2016 06:52 PM
83yotastockR
11
11-10-2015 06:54 AM
moparbay
10-06-2015 09:24 AM
JookUpVandetti
09-30-2015 08:58 AM
Quick Reply: P0171 with s/c, 7th ,and other stuff
