Oxygen sensor gone bad?
I've got check engine "PO136 code heated oxygen sensor bank 1 sensor2", I have checked 14 ohms resistance on terminals +B and HT of the sensor - as per alldata manual it should be between 11-16 ohm.
OBDII live data shows zero voltage from the sensor though.
Is the sensor gone?
The truck is 2000 4Runner SR5 V6 3.4L auto single cat. converter.
If I need a new sensor what brand is to go with, Denso or NGK?
Thanks.
Is the sensor gone?
Thanks.
Is that the front or rear O2 sensor? I have a spare front O2 sensor from my truck for sale, replaced it while trying to figure out a lean condition that turned out to be an exhaust leak. Still worked great but was too late to return it.
I would let it go for $25 shipped.
And yes it does sound like a bad O2 sensor.
Steven.m.paulk
07-24-2015 01:44 PM
