opinions on new gears
Old 01-13-2008, 05:59 AM
jjrgr21's Avatar
i'm running 255/85's, w/ tundra lift and ome's in the rear. i do alot of road tripping and pull my M416 trailer along. auto tranny, 3.4 v6.
i was first thinking of 4.88's but was told that may be a bit much for the highway. so do you think 4.56 would do well w/ the tires and trailer. i'd like to not deal with shifting on every hill i encounter.
thanks,
Jason
Old 01-13-2008, 06:27 AM
toy_tek's Avatar
I'm not a tire expert so I'm not sure how close your 255's are to my 285/75's. I believe they're within 1/2" diameter or so of each other. I regeared to 4.88 for similar reasons, with pulling a trailer in mind. It is slightly overgeared (higher RPM), but works good for towing, extra weight, and hills/mountains. Not to mention you can crawl a bit slower.
Check this thread that has a lot of comparison gearing/mph/tire info from various members. Specifically see post # 28
My numbers measured by GPS are as follows:
60.0mph @ 2250rpm
70.5mph @ 2600rpm
76.5mph @ 2800rpm
"Drove to Vegas and back over the weekend.
MPG averaged 16.5,
Moving miles per hour average was 68.5 according to GPS."
Old 01-14-2008, 07:57 AM
jjrgr21's Avatar
is your runner an auto or manual
Old 01-14-2008, 11:43 AM
Ian Rogers's Avatar
over gear it, the new tires are wider, heaver, taller then stock. All of these factors come in to play. I would go either 4.88 or 5.29
Old 01-14-2008, 11:50 AM
jjrgr21's Avatar
the new tires are narrower than stock, and only about 4lbs heavier each. i'm def not doing 5.29, it's a DD. i got 22-23 mpg towing out west in places, it would be awesome if i could get 19 towing with these. i'm leaning towards 4.88 b/c i have an auto
HollieJayyy
08-09-2015 07:59 AM
wolfpackfan33
08-02-2015 03:36 PM
yourrealdad
07-29-2015 11:08 AM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
A2theK
07-12-2015 10:46 AM
Quick Reply: opinions on new gears
