OME springs, is the A or B the longer one
I've been searching for a while and can't find this info. I replaced my rear axle and now the rear passenger side is sitting higher. I'm thinking I mixed up the rear springs, OME 891s. I know the longer one should be on the driver side but I don't really want to take them out if I don't have to. Right now the A is on the driver side, is that correct.
Take some measurements at all four corners and see where you're sagging. On my rig, the driver's side sits ~1/8" lower than the passenger side. Not enough to notice or do anything about...yet! But, if it continues to sag, it might be time for a trim packer up front and a small spacer in the rear.
Swampwalker
10-12-2015 09:49 AM
justdifferentials
09-05-2015 06:52 PM
