ome run3 installed=creaking noise from rear?
as stated i recently installed an Ome-run3 #" lift from Toytec. it drove fine for about a month but i am now hearing a creaking noise from the driver rear suspension somewhere. i am unable to pinpoint it currently. i did have the vehicle loaded on a trailer for about a day cinched down with a load binder. could this have bent something? i was attached to the hook an the rear of the frame and the excess chain was wrapped around the hitch. is it common for lifted vehicles to start to creak? also i can rock the side of the vehicle and hear it but even under the vehicle i cannot pinpoint it.
any insight to get rid of this noise would be appreciated.
THNX ETRNL
THNX ETRNL
I have a creak in mine as well when going over some bumps and when accelerating from a stop. I think mine may be my rear sway bar endlinks (which are totally shot). I have some wabfab ones on the way to hopefully take care of this. Yours may be the endlinks as well, as they are under serious tension on a lifted vehicle, and the rubber bushings wear pretty fast from the elements.
jerusry
10-19-2015 05:28 PM
Road Bull
10-10-2015 04:55 PM
