OME lift or OEM lift?
ok so i am contimplating on what lift i want... i just want to hear oppinions on these lifts. advantages, disadvantages to each and so on. yes i do know about the search but i keep getting mixed answers and it just doesnt help. ask any questions you might need.
With that being said, go OEM.
I would go OEM all the way. I say OEM because it is proven the best on and offroad capability. I know if you do any towing that the OME rear springs are a little bit better due to the stiffness. As far as the front OME coils go, I have seen through many threads of how they sag dramatically over time. i have had my OEM lift on for about two months and it is awesome on and offroad. They only thing you should know about the OEM kit is that the rear LC coils are a little high at first, but they do settle, mine has settled about 1" in about two months. If you do go with the OEM lift, you should throw on a
1" body lift and your 33's will fit very well. I have 33x12.50s and they don't even rub at full stuff(mostly due to the correct backspaced rims).
Daniel
Daniel
For 33's just go with the Tundra coils up front (with topout spacers) and OME 890's in the rear unless you're looking to do a significant amount of offroading and are willing to give up some gas mileage to run the rake the LC coils give you. If you need a bit more height just do a 1" body lift to give yourself more room.
the thing is i dont know if i want to put on a B/L. i dont know about yoda's but i've heard that with B/L's you start to have problems....
if i do the L/C coils how much gas mileage would i lose?
I have been getting decent(IMO) gas mileage with my LC coils. I have 3.90 gears,33x12.50 tires and I have been getting about 16.5 mpg in the city and 17-18 on the highway.
Daniel
Daniel
I was curious what brand your rims are and what is the amount of back spacing that you have?
I have 15x8 steelies with 4" backspacing. I bought them from www.wheelersoffroad.com .
From what I've seen with a 2.25 or less lift up front, a diff drop bracket isn't always necessary but recommend. To fit 33's you don't have to go any higher up front. Have you looked at Toytec's lifts. I haven't even gotten my next runner yet but i've been racking my brain on trying to compare the Toytec OME3run lift and the tundra/890 lift. I guess I'll be going with whichever is less expensive.
TUNDRA/890 LIFT
Toytec LIFT
TUNDRA/890 LIFT
Toytec LIFT
FS[PacNorWest]: 1992 4runner - 5VZ swap - Lifted
Swim
9
01-04-2016 10:47 AM
09-04-2015 09:27 AM
Luvmeye22re
08-04-2015 03:53 PM
