OME Installed! Pictures.
Yes, finally finished the OME lift. I didn't do any measurements but, I think I got a good 3" in the back, and probably only 2" in the front. The front coil/shocks took me about 2 hours each side. THe main problem I ran into was the lower shock mount bolt. That thing got stuck and I had to use a crow bar to get it out.
Anyways, here is the BEFORE picture:
And AFTER:
And AFTER:
Hey, so can someone tell me where I put the FRONT trim packers?
Is it under the plate that holds the coil , so the packer is right on top/touching the coil? (I HOPE NOT), or is it on top of the plate, inbetween the top mount and the plate that I ws just talking about.
Hopefully hte latter, then all I would have to do is take out the top 3 bolts, and slide the strut out stick that thing on top and put it back in and bolt.
Flying91
45
04-11-2024 04:39 PM
Luvmeye22re
08-04-2015 03:53 PM
