OME heavy with Rancho 9000?
Old 12-31-2002, 02:43 AM
02Runner's Avatar
Has anyone had or used the Rancho 9000's adjustable rear shocks with OME Heavy springs? I know many of you use the OME comfort shocks but my Ranchos are adjustable and are already on the truck. Oh that dreaded top bolt. That thing sucks.
I plan on pairing SAW coil-overs with this rear set up from Mike at Xtreme.
Also kind of a side question, I can't stand the Ford explorer type of body roll I'm getting. Should I also replace my sway bars with addco or will my suspension set up be enough?
How easy is the install on these (all) as I can't afford to pay ridiculous labor charges? SSchaefer has a great site with instructions good enough for the mildly retarded, but I'm not sure if they're good 'nuf for me. JK.
Thanks to Schaefer: http://fastq.com/~sschaefer/index.html
Old 12-31-2002, 07:19 AM
XtremeOff-Road's Avatar
Hi there, if you are planning on running OME coils in the rear, then the only shock I would recommend you pair the coils with are the OME shocks as they are designed to be used together. If you want to run the Downey rear coils, then I would recommend you utilize the Bilsteins in the rear. Please let me know if you have any other questions!
Regards,
Mike
ZGjethro
06-07-2017 11:04 PM
A2theK
10-14-2015 07:10 AM
Obmi
10-04-2015 11:30 AM
83
09-27-2015 04:13 PM
adamk
09-24-2015 03:59 AM
Quick Reply: OME heavy with Rancho 9000?
