OME/ARB/Revtek?!
OME/ARB/Revtek?!
My Sahara bar may be getting here as soon as next week!
I KNOW that once it gets on, I'm gonna want more lift. My question is if I could add a revtek top out spacer to the 882's I have now? That would give me about .5" more, no? Could I go even higher?
CV's scare the CRAP out of me. As it is now my CV's are at a somewhat normal level, and I dont worry about them as much as I could.
In my situation with the lift, my control arms are actually tilted downwards (assumed normal with a lift). Does the top out spacer fix this to an extent? Or am I misunderstanding this?
you have 882s and no bumper and your CVs are at a fairly stock level? yea right!
the guys i know with 882s are getting 2.5" lift with ARB bumpers and winches.
The levels ARE pretty decent... Yes I know i'm getting the arb to level them out more, but I was thinking maybe it would level it more than enough and I could go back to pushing the limits?
They've settled quite a bit more level after the 1k miles I've put on the lift.
Originally Posted by RTdawgs
the 882s will not sag much with only a bumper.
IMO, those CV angles are too much.
We'll see about all of this though.
Anybody know more about the Revtek Top Out?
You have one, so theoreticly I could also run one once I get the bumper?
I'm just curious because I'm a bit "nose down" right now, and I'm afraid it'll only go farther.
you can add a revtek topout spacer to your OME coils.
if i was in your shoes, i would install your bumper, drive about 5000 miles, decide if you want more lift, determine amount of desired increase, select a spacer or other option from there.
Thanks for the advise. I knew it could be done, but not sure it was safe with the bumper.
5k miles shouldn't be bad as i'm going on a 2k road trip to WY next weekend..and hopefully my bumper should be here next week.
