OME 880/906 combo, I'm confused, HELP!
Old 06-13-2007, 06:35 PM
aviator31's Avatar
I used the search and got even more confused. I have a 99 4Runner "sport" and put OME 890s front, 906s rear with all new OME struts and shocks. I was under the impression it would give me about 2" lift over stock, but from what I've read on here that combo doesn't give any additional lift over stock? Now my quandry is that I was planning on running 285s on it, what will I have to do to make it work???
Old 06-13-2007, 06:50 PM
FUZION's Avatar
it'll would have given you 2 inches if you had any year other than 99 4x4's. But now you probably only got about an inch. For 33's you either need a toytec lift or tundra/ome890..
Old 06-13-2007, 07:02 PM
aviator31's Avatar
What I was afraid of. So, I need a whole new setup? Where is the cheapest place to get the Tundra coils for the front? Could I not use a trim packer or 2 in the rear coils? Really wanting to run 285s...
Old 06-13-2007, 07:06 PM
Joshs98Runner's Avatar
Let me know if you decide to sell the 906 coils. Where are you located?
Old 06-13-2007, 07:10 PM
aviator31's Avatar
AR, I'll let you know soon. You want the front coil and strut assembly also? They have about 20k on them, no abuse.
Old 06-13-2007, 07:14 PM
No thanks I am going with the Tundra fronts and already ordered some tokico front struts. Maybe we could try to gather up a group buy for some Tundra front coils...
Old 06-13-2007, 07:23 PM
aviator31's Avatar
I'm game, let's get it worked out. I guess the 906s and the Tundra front setup would be pretty level and give about 2" all around?
Old 06-13-2007, 07:27 PM
Yeah close, I think the Tundra fronts give about 1.5 or so naturally, and most guys put in a 3/8 spacer that brings it to almost 2". I might be a little low on those numbers. Do a search for a thread called "New TRD front setup" or "New front setup" by a user named Bamachem and you should find a really nice writeup with tons of info on doing the setup.
Old 06-14-2007, 07:12 AM
FUZION's Avatar
http://www.4rnr.net/suspension.html
Toyota Parts 4 U offers discounted prices for the tundra coils.
Old 06-14-2007, 07:29 AM
WarEagleSR5's Avatar
Aviator, let me know if you want to sell your current set up.
Old 06-14-2007, 07:50 AM
j-man's Avatar
the ome 890's didnt give my 99 any lift. i ended up using the 891's which gave me 3", but many think they are too stiff - not for me tho. also the landcruiser coils give about 3" in the rear and are softer than the 891"s.
Old 06-14-2007, 08:45 AM
aviator31's Avatar
I measured last night, bottom of fender to ground with Nitto Terra Grappler 265/75/16 it is:
Back 37", Front 36". What do most of you guys have in the back with the 890/891, LCs, etc?
Old 06-14-2007, 06:51 PM
FUZION's Avatar
https://www.yotatech.com/forums/f79/gerdos-profile-85724/
https://www.yotatech.com/forums/f79/paddlenbikes-2000-4runner-profile-77088/
ZGjethro
06-07-2017 11:04 PM
A2theK
10-14-2015 07:10 AM
Swampwalker
10-12-2015 09:49 AM
Boomer8404
09-20-2015 06:15 PM
justdifferentials
09-05-2015 06:52 PM
Quick Reply: OME 880/906 combo, I'm confused, HELP!
