Okay...feed me.
Old 03-13-2007, 11:52 AM
BYAHnate's Avatar
Okay...feed me.
I have decided that I officially want a 1"-1.5" lift from just coil springs. I want some that will handle well, take to offroading well, and not sag. Spit it out to me. Which set? PP's, OME's, OEM , what? I have about 300 to spend.
Old 03-13-2007, 11:53 AM
mastacox's Avatar
What vehicle do you have? Are you looking for a front and rear lift or just rear?
Old 03-13-2007, 11:54 AM
mkgarrison5's Avatar
how can you do an oem lift on a 2002 tacoma?? how much does it run? just curious
BYAHnate's Avatar
Oops. Sorry, 1998 Limited 4x4. Rear and front.
Old 03-13-2007, 12:05 PM
mastacox's Avatar
Here's what you'll want to look at:
Sonoran Steel Factory Parts Lift Kits
And if you get a lift, don't forget this:
Extended Panhard
Old 03-13-2007, 12:21 PM
Stevo3's Avatar
Extended Panhard
Yo mastacox, i got 3 1/2'' of lift in my rear and didnt get the panhard bar
Old 03-13-2007, 12:30 PM
mastacox's Avatar
tsk
Old 03-13-2007, 12:32 PM
Stevo3's Avatar
Well i even measured both sides. there wasnt a difference. When ever i do the 6'' lift then ill get the bar
Old 03-13-2007, 01:14 PM
YM13's Avatar
for 300 dollars all you could probably get is some spacers and new shocks for the rear....I'm planning on doing the same thing (no more than 2.5 inches of lift...preferably 1.5) and I want to stay in a range below 500. I want to change out the shocks on the front and rear so what i've come up with is the spacers.....i dunno.....
Old 03-13-2007, 01:25 PM
Hugo's Avatar
For a small lift, Downey coilovers are cool. They allow you to dial between 0" and 3". Get the 2" rear ones, they settle to 1,75" or so.
Old 03-13-2007, 03:24 PM
MTL_4runner's Avatar
Get a set of 881/906 OME springs all around.....look at my sig for pics.
Geez, that was easy.
Old 03-13-2007, 05:22 PM
HUTCHSTACO's Avatar
he doesnt want to spend much... check out cornfed suspension and toytec, both company's make a solid space lift
Old 03-13-2007, 10:32 PM
FUZION's Avatar
Toytec
Old 04-15-2007, 07:47 PM
SurfRunner98's Avatar
how much for the whole set amd about how much lift did u get?
Old 04-16-2007, 09:44 AM
potsy's Avatar
Location: Ocean Beach, CA Five square miles surrounded by reality.
rear coilovers? for a '98 4runner there is no such animal.
Old 04-16-2007, 10:25 AM
You can get the full setup from wheelers or TRDparts4U (strap22) and it will run you just over $600 or so.
http://www.wheelersoffroad.com/ome4runner.htm
www.trdparts4u.com
On your 98, you should get about 1-1.25" up front and 1.5-1.75" in the rear.
ladybugRC
458
08-21-2020 10:41 AM
zytra
01-24-2019 03:16 PM
Chicken12
10-14-2015 03:54 PM
whiteyota93
09-29-2015 02:31 PM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: Okay...feed me.
