OK NOT to use Revtek spring compressor
Old 05-03-2004, 10:59 AM
4RunnerFever's Avatar
Question OK NOT to use Revtek spring compressor
I'm installing the lift next week and the directions look very straight forward with one exception. Revtek recommends using their spring compressor. Any problem NOT using it, but using the hook type instead??
peace out
Old 05-03-2004, 12:28 PM
SD4Runner's Avatar
peace out
I used a OEM spring compressor on my 4th gen. Worked perfect. (In a pair)
Old 05-03-2004, 12:38 PM
r0cky's Avatar
I used the Craftsman coil spring compressors, worked just fine other than some sore arms afterwards.
Old 05-03-2004, 12:39 PM
waskillywabbit's Avatar
Talking Spring Compressors
They all do the same thing.
You go girl!
Old 05-03-2004, 12:40 PM
Yea, I'm expecting sore arms so I'm preparing by Thanks for the input.
Old 05-03-2004, 12:44 PM
02Runner's Avatar
Ditto here on the Craftsman.
An Impact wrench is also a good idea.
Doug
Old 05-03-2004, 12:47 PM
r0cky's Avatar
DOUG! Long time no see.
Yeah, if you don't want buff arms, or sprained wrists, use an impact wrench. I would've ,... just so happens I LIKE having sprained wrists and strong arms.
Makes it a lot easier to keep your wrists relaxed while playing the geeee-tarr.
Old 05-03-2004, 01:22 PM
SD4Runner's Avatar
The wrench makes it sooo nice... We would take turns compressing because it was so fun... get your favorite chair ... and listen to the beat of the impact wrench.... so soothing.... hehe.
Old 05-03-2004, 01:28 PM
r0cky's Avatar
I'm going to hit you with a stick for that post!!
GET OVER HERE!
Old 05-03-2004, 01:55 PM
SD4Runner's Avatar
hehe. Somehow I knew you wouldn't be happy with that...
Trust me, I feel for ya... *hug*
Old 05-03-2004, 03:59 PM
r0cky's Avatar
hehe, well, i'm just glad your spring compressor experience was so soothing.
*hug*
Old 05-03-2004, 09:13 PM
ssbogger's Avatar
I used the ones from Advance or auto zone. I cant rember. You can rent them there for free, you just have to leave a deposit. Make sure to get the ones that go on the outside of the spring and do your best to get ahold of an impact wrench. I couldnt imagine doing it by hand but maybe im just spoiled.
Glad to see you decided on getting one. You'll love it. Soon enough it will start looking stock again and you'll be wanting more lift...
Old 05-03-2004, 10:10 PM
4x4taco's Avatar
i used one from advance or autozone too, the impact wrench isn't necessary even for stiff springs (OME 882s) but it would probably help, i used a 1/2" drive socket with about a 1.5-2' ratchet which provided plenty of leverage and you can always throw a cheater bar on it
Old 05-04-2004, 03:44 AM
Anybody want to give me an impact wrench and ship it to me free??
Seriously, thanks for all the input. I know what you mean Sam, this hobby kind of gets under your skin. I already want an ARB front locker and a rear bumper/tire carrier.
Lottery anyone?
Old 05-04-2004, 06:31 AM
By all means Mark, I've still got to get tires. As an aside, do you have a preference between your two trucks?
Old 05-04-2004, 07:54 AM
WATRD's Avatar
peace out
I have done a half dozen spacer lift installs and I have yet to even see a Revtek spring compressor Use what you have access to, but use it safely, carefully and slowly to ensure you finish with the same number of appendages you started with.
Old 05-04-2004, 10:14 AM
chuckd's Avatar
I used a manual compressor and a plain-jane manual wrench. While Dan 90 was being nice enough to change my brake pads, I fought that Mother F'er for what seemed like hours. I ended up compressing the front passenger spring 3 times. The first time, then it came loose after I was 2/3 done, had to start over, then a third after I incorrectly reassmble the top (left off a washer.) Talk about fun. Uncompressing is almost as bad compressing.
Old 05-04-2004, 02:23 PM
r0cky's Avatar
eeek. chuckd, yours came loose? that is scary!!!
i had to compress and decompress one side at least 6 times!
but yeah ... all i recommend is that you just be sure to do a little at a time on one side, and then the same amount on the other side, so it's even.
even if you don't get ahold of an impact wrench, you'll be just fine ... it will just take a little longer, and a little more stamina. but it is definitely possible to do.
Old 05-05-2004, 07:00 AM
chuckd's Avatar
I was doinga little at at time, but one side just slid around and came loose. Sucked
justdifferentials
Just Differentials
06-13-2022 07:40 PM
justdifferentials
14
06-11-2017 08:36 PM
punks_is_4x4
05-31-2016 06:03 AM
RickyD
10-02-2015 07:53 AM
justdifferentials
09-05-2015 06:52 PM
Quick Reply: OK NOT to use Revtek spring compressor
