oil plug question
Old 11-14-2005, 01:14 PM
mike_04's Avatar
oil plug question
what type of washer do you use with you oil drain plug?
plastic
brass
aluminum
or do you have an engine oil drain valve (http://www.fumotovalve.com/)
Old 11-14-2005, 01:22 PM
Silver_Truck's Avatar
plastic...the factory one that comes on the truck or from the dealer
Old 11-14-2005, 09:55 PM
Flamedx4's Avatar
Washer?
Old 11-14-2005, 10:03 PM
jimbo74's Avatar
i sue the plastic ones... that is what comes on the replacement drainplugs you can buy @ the autoparts stores
Old 11-15-2005, 01:06 AM
leebee's Avatar
get the crush washers from the stealer or auto parts store nearest you. i bought gear oil to do the diff fluids and they threw in 10, not a bad deal at all.
lee
Old 11-15-2005, 04:07 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
A thread was recently posted (this past week, if I recall) about drain plug washers and valves. Use the search feature. The discussion of that particular thread mainly dealt with opinions on replacing the washer vs. reusing and some members mentioned they were using the drain valves.
Old 11-15-2005, 04:09 AM
sandiego's Avatar
There is a washer on there? I don't think mine has a washer and it doesn't leak oil.....I hope. You guys are sure there is a washer in there?
Tony
Old 11-15-2005, 04:18 AM
Rick F.'s Avatar
Tony
You'd know if it was leaking. Perhaps you haven't noticed that you have one since the washer usually comes off with the drain plug as 1 piece. Some of them are metal crush washers, some are fiber and some are plastic or rubber. If yours isn't leaking, I'd just look at it the next time you do an oil change and have 1 on-hand, if you're uncomfortable about it. The flange on the drain plug will often provide a good seal against the pan, but I'd put a washer on next time if you don't have one.
Old 11-15-2005, 09:40 PM
sandiego's Avatar
I will check into that. Thanks for the tip.
Old 11-16-2005, 04:21 AM
pat161's Avatar
Right now I use a drain valve, it works great and you don't need to remove the skid plate to avoid covering it in oil. I do remove the drain once a year to make sure it doesn't seize up in there. Before I got the drain I never used a washer for the plug, pretty much was wrecked the first time so I didn't bother putting it in, never lost a drop of oil past the plug.
smthwsn357
12-04-2023 02:08 AM
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
09-04-2015 09:27 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: oil plug question
