Oil in my airbox!!!!
Old 06-13-2004, 03:56 PM
mattk's Avatar
Went to change my air filter today and noticed a quite of bit of oil laying in the bottom of the air box. Is this normal or is there something i should be looking for.?
Old 06-13-2004, 04:06 PM
Bob_98SR5's Avatar
mattk,
assuming you have an amsoil air filter, if its a puddle, yes. if its just a thin film, its ok.
what i usually do is squeeze the filter in between sheets of paper towels. also, i flip the air filter (after re-oiling) around after a few days inside the air box.
bob
Old 06-13-2004, 04:23 PM
mattk's Avatar
Actaully it is whatever filter is in it when i bought it used so i have no idea. Looks like an STP or something. Was thing of a K&N to replace it but not sure. Any ideas? And what would the oil be from thats in there?
Old 06-13-2004, 05:33 PM
Bob_98SR5's Avatar
mattk,
there is absolutely nothing that can drip from the plenum, through your throttle body, etc all down the way to your airbox. my best guess is that he had a K&N or Amsoil in there.
remove your stock air filter, clean all that stuff out w/ some shop rags or paper towels. if you get any funky lean air codes, most likely your MAF sensor is covered in that same oil. now don't freak out because i said that---just keep taht in the back of your head. do a search on MAF sensor cleaning. its pretty simple (just use contact cleaner).
bob
Old 06-13-2004, 05:39 PM
mattk's Avatar
Thanks for the info ill clean it out and see what happens
Old 06-13-2004, 05:44 PM
Bob_98SR5's Avatar
matt,
if you want to be really thorough, why not disassemble the entire airbox from the air intake tube and clean the entire airbox out? and from there, you can do the following maintenance items:
- clean the MAF sensor wire
- clean the throttle body
all you will need is some contact cleaner (aerosol), throttle body cleaner, lots of rags, and a toothbrush.
do a search on "MAF sensor cleaning" and "throttle body cleaning" and see if you're up to this (very easy) task.
bob
edit: also, you might want to purchase an "O gasket" from the dealership vs the D-shaped gasket. this is the gasket that goes in between the air intake tube and the throttle body. after putting doing all these items, you can show that new girl in logistics your O-face.
Old 06-13-2004, 05:51 PM
mattk's Avatar
Cool man i think i will do all you suggested and what is the point of the o gasket will it help my motor run better? Sorry dont know much about the gasket thing!
Old 06-13-2004, 06:11 PM
Bob_98SR5's Avatar
...less restrictive shape will allow the air to flow better, that's all. do you gain extra hp? hardly. just think of it as the new, improved gasket.
bob
Old 06-13-2004, 10:11 PM
humanoid's Avatar
bob
Hey, Bob, do you have the part # for the "O" ring?
Old 06-13-2004, 10:20 PM
keisur's Avatar
pm <96 Runner>
he's who I got my "o"gasket from. I think he knows the number.
Old 06-13-2004, 10:30 PM
humanoid's Avatar
Originally Posted by keisur
pm <96 Runner>
Cool, thanks! Just PM'd him...
Old 06-15-2004, 11:04 AM
radrex's Avatar
That is where you are wrong....
mattk,
bob
Actually blow-by could blast oil all the way up the plenum and into the air-box. very doable if you have bad cylinder rings.
Check your compression and look real hard at your Spark Plugs - also look closely at your PCV Valve (Or go ahead and replace it).
Old 06-15-2004, 11:08 AM
keisur's Avatar
all the way through the TB and the intake tube and the MAF sensor too? I highly doubt that.
Old 06-15-2004, 03:20 PM
TACOMANATOR's Avatar
Could be a bad PCV, a common problem on the Heep Cherokee but unlikely on the Toyota given the location of the pvc tube. Change the pvc valve and clean the tube.
Old 06-16-2004, 06:50 AM
HondaTec521's Avatar
Common on older Hondas also(PCV) but if the air fiter is dry how did the oil get past it?
calderp
Engine Swaps
08-16-2016 05:15 PM
Toyvana
07-29-2015 10:47 PM
yourrealdad
07-29-2015 11:08 AM
calderp
07-27-2015 09:58 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: Oil in my airbox!!!!
