OIL LIGHT CAME ON? need advice - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-16-2009, 02:09 PM   #1 (permalink)
sfm7315's Avatar
Hello everyone I need some expert opinions asap!!!!.
This morning while doing about 65mph on freeway the oil light came on!
I pulled over and checked oil -it's fine. Just had it changed at dealer last week. Engine runs smooth -no issues . I took it to dealer they had it all day checked it out no visual problems but I have to bring it back tomorrow because the told me they need a speacial adaptor to fully diagnose it. Can someone give me ideas on what to expect before they try to hose me!!
It's a 98 4Runner Limited 133000 miles on clock
sfm7315 is offline
Old 03-16-2009, 06:42 PM   #2 (permalink)
Gerdo's Avatar
You need to make sure that you have oil pressure. You can hook up a pressure gauge or you can just replace the oil sending unit. If you do have pressure then the oil sending unit is probably bad.
__________________
2000 4Runner Sport, 3.4L, 5 Speed, Custom Front Winch Bumper, Opened intake, K&N Airfilter, BFG A/T LT265/70R16, Bilstein Shocks, FreeFlow Exhaust, Poly Rack Mounts & Swaybar Mounts, Tundra TRDs up front and OME 891s out back. ToyTec Panhard Bar Drop. SS Front Diff Drop. Home-built 2x2 Sliders. ARB rear locker, OBA, CO2 See My 4Runner!
Gerdo is offline
Old 03-16-2009, 06:54 PM   #3 (permalink)
Skrillah's Avatar
Send a message via AIM to Skrillah
Quote:
Ditto
__________________
1997 Toyota 4runner 4x4, 2.7L, Auto, 146k miles, KC Slimlites, Bilsteins, OME 881/890s, Custom Westin Push Bar, Brembo/Hawk Pads, Yakima Gear, Midland CB, 265/75/16 Bridgestone Revos, Limited 5-spoke rims (Custom),Herculined Rocker Panels, Diff. Breather mod,Deckplate mod,4.56 gearing, Pioneer head unit w/Ipod connection and Sirius Sat. Radio.
Skrillah is offline
Old 03-16-2009, 06:59 PM   #4 (permalink)
sfm7315's Avatar
Is the sending unit big bucks?
sfm7315 is offline
Old 03-16-2009, 07:09 PM   #5 (permalink)
gohawks's Avatar
Quote:
No.
I guess really depends on your definition of big bucks. Aftermarket is pdc, pretty darn cheap.
__________________
SERENITY NOW!!
gohawks is offline
Old 03-16-2009, 08:50 PM   #6 (permalink)
neoworm0's Avatar
Send a message via MSN to neoworm0
I have a good one I can sell you. OEM.
__________________
1995 Toyota PU SR5. 2000 3.4l V6 and a few other mods.
my album:
http://www.yotatech.com/album.php?albumid=101
my SAS:
http://picasaweb.google.com/areinhol...eat=directlink
www.overlandcanada.ca
www.alltracwagon.net
neoworm0 is offline
Old 03-16-2009, 09:05 PM   #7 (permalink)
86tuning's Avatar
Quote:
Originally Posted by gohawks View Post
No.
The sending unit is definately not big bucks.
The alternative is definately big bucks. HUGE BUCKS.
__________________
- Brian
84 toy pickup
mostly stock
Last edited by waskillywabbit; 03-17-2009 at 07:00 PM. Reason: Inappropriate language edited
86tuning is offline
Old 03-17-2009, 09:17 AM   #8 (permalink)
Nuthuts96's Avatar
Location: Burlington, VT previous: Everett, WA; Bellingham, WA
i laughed...out loud. thank you!
__________________
Scott
1996 White 4Runner-4x4-SR5-5 speed-gold trim
140k-265/75/16 Yokohama Geolander AT/S
Cupholder Mod- Overhead Console Mod
Last edited by waskillywabbit; 03-17-2009 at 07:01 PM. Reason: edited inappropriate language in quote
Nuthuts96 is offline
Old 03-17-2009, 06:06 PM   #9 (permalink)
sfm7315's Avatar
Ok I'm going to get my lumps on this but here it is: Dealership changed oil sending unit but not 100% sure it was the cause of light coming on. Anyways the total was $168.00 Cnd.
Oil pressure readings were:8.1psi at idle and 20-30psi at 3000 rpm
Does that sound normal?
sfm7315 is offline
Old 03-17-2009, 06:27 PM   #10 (permalink)
rbh261's Avatar
Straight from FSM
3. REMOVE OIL PRESSURE SWITCH
Using SST, remove the oil pressure switch.
SST 09816–30010
4. INSTALL OIL PRESSURE GAUGE
5. WARM UP ENGINE
Allow the engine to warm up to normal operating temperature.
6. CHECK OIL PRESSURE
Oil pressure:
at idle 29 kPa (0.3 kgf/cm2, 4.3 psi) or more
at 3,000 rpm 245 – 520 kPa (2.5 – 5.3 kgf/cm2, 36 – 75 psi)
Looks like you may be a little low at 3k rpm, but this can be dependent on oil condition,oil weight and I would imagine filter condition may affect your results too. I use 5w-20 Syntec blend and would expect a lower number if I checked my pressure. My '77 Jeep holds about 60psi, but I use 20w-50 oil in it to get it there. 10w-30 results in lower pressure. Without a gauge, I would probably stick to 10w-30(in my Jeep) and never think twice of it.
__________________
'98 4-Runner
SR5 V6 Automatic
Intake elbow removed, Sony head unit, Sony Class-D amp, Sony 10" sub enclosure and F&R components
Brad Hall
Service Advisor
Nelson Automotive Group
201 Commonwealth Blvd.
Martinsville, VA 24112
276-638-2331
www.autosbynelson.com
rbh261 is offline
Old 03-17-2009, 06:54 PM   #11 (permalink)
sfm7315's Avatar
Oil change was done 2weeks ago at dealer, hmmm I wonder if they put on the right filter?, so you are suggesting to switch to 10w30?
sfm7315 is offline
Old 03-17-2009, 07:02 PM   #12 (permalink)
rbh261's Avatar
No, not suggesting. Just saying heavier weights can increase oil pressure. On the other hand, heavier oil may not flow at a high enough rate to do the job. I work in a Ford service dept. and I can honestly say I would probably stick to a weight close to manufacturers specs. I would, however, use the best oil I could afford to use if I thought I was having a problem with oil pressure. A heavier oil isn't going to necessarily provide better lubrication, although it will show you higher oil pressure. I used my Jeep as an example, but it is a '77 model and the heavier weight is probably beneficial in this application. I hope I'm not confusing you.
__________________
'98 4-Runner
SR5 V6 Automatic
Brad Hall
Service Advisor
276-638-2331
rbh261 is offline
Old 03-17-2009, 07:15 PM   #13 (permalink)
sfm7315's Avatar
point well taken, thanks for the advice!
sfm7315 is offline
Old 03-18-2009, 06:18 PM   #14 (permalink)
86tuning's Avatar
If the oil is HOT during this check, then yes it's normal and perfectly acceptable.
If the oil was COLD during this check, you have low oil pressure, which is often caused by excessive bearing clearances. This would be very labour intensive to repair.
If it were my car, I'd run a synthetic 10w30 and see what happens. If the oil light doesn't come on anymore when the oil is HOT HOT HOT then just keep on truckin.
__________________
- Brian
84 toy pickup
mostly stock
86tuning is offline
Old 03-19-2009, 02:46 AM   #15 (permalink)
ARB1977's Avatar
I run 0W30. At cold start its around 75 psi. Once warm on the freeway (2200 rpm or so) between 45-50 rpm.
__________________
2002 TACOMA 3.4L 102K AND COUNTING
ARB1977 is offline
Tags
1995, 4runner, at, back, change, check, drops, light, oil, pressure, removal, rpm, sending, temp, toyota, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
need some advice on oil. mikesaskater Newbie Tech Section 5 02-13-2009 03:19 PM
A/T oil temp, Charge Light, and brake light come on Luvmeye22re 86-95 Trucks & 4Runners 6 11-12-2008 09:46 AM
A/T oil temp, Charge Light, and brake light come on 86 $Runner 22re 5spd swap Luvmeye22re 86-95 Trucks & 4Runners 2 11-09-2008 11:09 AM
Driving light advice Kraeken General Vehicle Related Topics (Non Year Related) 7 07-23-2007 08:15 PM
Charge Light/ Oil Light 87toylet 86-95 Trucks & 4Runners 6 12-09-2006 12:18 AM
2009 InternetBrands, Inc.
