Oil Leak 02 Auto 3.4L - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-09-2009, 08:49 AM   #1 (permalink)
xcmountain80's Avatar
Well I have a slight oil leak and by the looks of it it has been slowly coming out for some time. I'm guessing valve cover gaskets but tell me what you think. The drivers side is leaking to the point of a slow drip where as he pass side is barely noticeable and has no speed or culmination point.
A
xcmountain80 is offline
Old 11-09-2009, 09:50 AM   #2 (permalink)
brian2sun's Avatar
Yeah it looks like the valve cover gaskets to me. I'm sure you checked the oil filter too (mine loosened up once and started leaking), but it looks pretty saturated so that may be part of the issue.
__________________
97 4Runner SR5 3.4L 4x4
285/75R16 Dunlop M/T Maxx Tractions
Front - OME 883s & N91SC shocks
Rear - OME 891s N86C shocks
ARB rear locker
ARB Bullbar
4.88s
Pulled my ABS fuse mod
My 4th Toyota truck
brian2sun is offline
Old 11-09-2009, 12:49 PM   #3 (permalink)
Yeah the more I think about it and the area of saturation the more I think the valve cover gasket. I'll call Toyota today and see what they will run me. I can't imagine this is a difficult job compared to removal and re-install of the fron and rear thirds.
Aaron
Old 11-09-2009, 03:14 PM   #4 (permalink)
Got the seals and forgot the tube seals (pick them up tomorrow). Will do a swap on Thursday.
A
Old 11-09-2009, 05:35 PM   #5 (permalink)
jrallan26's Avatar
Look on the bright side, the oil leak will keep the frame from rusting....
__________________
My Profile
jrallan26 is offline
Old 11-09-2009, 05:51 PM   #6 (permalink)
I have no rust, other than the typical exhaust rust and any spot we whacked a rock in our travels.
A
Old 11-09-2009, 06:18 PM   #7 (permalink)
02_Limited's Avatar
Send a message via AIM to 02_Limited
Same thing happened to me about 15k ago at 125k. Just needed new gaskets
__________________
2002 Limited 4wd
On the outside:
3.5" full OME lift, 33" Terra Grapplers, TRD cat back, full LED lighting/LED tails, amber Hella 500's and more odds and ends
On the inside:
TomTom|Infinity|Kicker 08ZX750.1|08CVR12|Jensen VM9412/iLink|Dynamat|Complete LED conversion
In progress:
ZEX NO2 injection
Lockright
Quote:
Originally Posted by habanero View Post
Throttle Positioning Spider?
02_Limited is offline
Old 11-09-2009, 06:26 PM   #8 (permalink)
It's probably been slowly leaking since 100 and change but a slow leak at that. I hope this fixes the leaks as I hate them with a passion.
A
Old 11-10-2009, 02:54 PM   #9 (permalink)
Ok driver side done, now on to the pass side. I think I will wait until my dynamic tensioner pulley comes in and oil change kit for SC b4 I put it all back together.
A
Old 11-11-2009, 03:33 PM   #10 (permalink)
Ok, both sides done and fluro additive added to make certain leaks are evident if I missed something.
A
Old 11-11-2009, 06:45 PM   #11 (permalink)
20 miles down and no glowing leaks with the CSI kit. I simple greened and wash the old yuk off.
A
Old 11-11-2009, 07:21 PM   #12 (permalink)
Kiroshu's Avatar
Yea just clean it all up and watch it for a week and see if it doesn't lea by then your good.
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
(Still working on restoring her)
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
(sold)______________
(Was my fastest truck i miss her...)
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
(was my quietest and slowest yota.)
Kiroshu is offline
Old 11-11-2009, 07:53 PM   #13 (permalink)
The leak detection can be bought for less but mine covers ac, coolant, and oil based liquids. Purchased for $68 at Napa and comes in a storage case. It has helped me source a evil t-case leak that led to a double gasket replacement and shifter seat replacement.
A
Old 11-12-2009, 05:16 AM   #14 (permalink)
check the valve covers bolts- mine were leaking and the bolts were finger tight, guess they loosened up over the miles, tightened them and leak went away, doesn't get any cheaper than that
lexustech is offline
Old 11-12-2009, 03:13 PM   #15 (permalink)
Kiroshu's Avatar
^Doesn't get any luckier than that either....
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
Kiroshu is offline
Old 11-15-2009, 09:55 PM   #16 (permalink)
Well after 230K I decided I should just replace the seals and re RTV the spots that require it. No leaks do date, though the oil filter came loose the other day and made me think twice.
A
Old 11-16-2009, 07:48 AM   #17 (permalink)
BajaRunner's Avatar
Wow I am surprised that they were your valve cover gaskets. I would have almost bet money it was the rear main.
Because my leak looks exactly the same... slow moving, but I know the rear main has a leak. I checked all the gaskets up top and they seem OK. Maybe I should replace them anyways. )
__________________
BajaRunner
1996 4x4 3.4L SR5 4Runner
6" IFS lift * Front: TRD Coils/Bilstein 5125 * Rear: FJ80 Shocks/Coils * ARB Tacoma bumper * 35" MTR's and E-locked!
BajaRunner is offline
Old 11-16-2009, 08:29 AM   #18 (permalink)
The tip off was the leak was coming from the front of the engine toward the top, the valve covers were covered with old oil and dirt, the oldest was not shiny anymore, where as the newer or consistent leak toward the front was fresh and wet. Now before you go replacing things I recommend the CSI kit with fluorescent dye and a UV LED light and some glasses. This will save you time and frustration. I know you can get just the dye, light and glasses for way less than the $70 I paid for the kit.
A
Tags
30l, 34, 34l, back, changing, clear, fresh, leak, leaking, oil, t100, tacoma, toyota, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
