| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Oil filter empty on 22re?
__________________
mike '89 4Runner DLX: 2" OME rear springs, 1 5/8" RB BJ spacers, Diff Drop, 32" MT/R. '90 4Runner SR5: Stock Suspension, 32" MT/R . '07 4Runner SR5: 2" OME Rear Springs, Donahoe Coil Overs, Total Chaos UCA, 275/70-17 MT/R. '76 Jeep CJ-5: 4" Lift, 33" BFG MT. '87 Saab 900S: All stock '99 Subaru Legacy GT: All stock |
#2 (permalink) |
It's normal, don't worry. Only a small amount of oil is in the filter after 2 hours of sitting. It would be better if the filter were vertical instead of angled, so this is not the best possible design from Toyota.
#3 (permalink) |
whew. good to know. on every other car i've ever changed oil on, the filter was tilted the other way and never drained back into the engine. i just wasn't expecting to have the filter be empty.
__________________
#4 (permalink) |
Just curious but what brand of filter was it?
__________________
Dave Currently own no Toyotas :( |
#5 (permalink) | |
Quote:
__________________
#7 (permalink) |
Yea Frams are no good, I use WIX 1515 which is twice the capacity of standard filter. Looks like it belongs on a v8 instead of a 4 poper.
__________________
'86 4runner 22RE, 5-speed, LC Street EFI head w/ cam, LC Pistons, ARP Head Studs, Downey header, Dynomax 2 1/4" full exhaust, VDO water temp guage, 01-03 Tacoma cd\tape radio with 10" Bazzoka, Downey 2" rear springs, GDI radiator, Torus fan DONE!!!! '68 Ford Mustang Fastback Daily driver with a built 289 and a streetfighter trans.(Retired) 98 Subaru Outback-Took over daily driving duties MicroMatic.com Waco93.com |
#8 (permalink) |
Guest
2 hours of sitting and it was completely empty? That's a strong indication that the filters anti-drain back valve is leaking. You will normally get oil draining from the filter even after a few days of sitting.
In fact, if it was as dry as you make it sound, it would concern me that the filter wasn't even in operation. This can happen if the filter collapses internally, or blinds, opening up the bypass valve. |
#9 (permalink) | |
Quote:
__________________
#10 (permalink) | |
Quote:
#11 (permalink) | |
Guest
Quote:
#12 (permalink) | |
Quote:
__________________
#13 (permalink) | |
Quote:
#14 (permalink) |
I started using a Purolator Pure One that has a silicone anti drainback valve. These are better than the rubber and shouldn't leak. I think on Bobistheoilguy site there was talk of who supplied the Toyota filters. It seems you can get a number of different part numbers for the same vehicle. Some of the new ones may not be as good as the old ones. Try using this type of filter and see if the noise goes away.
Its very bad to have an empty filter in a 22re at startup. This is what causes broken timing chains from lack of oil to the chain tensioner.
__________________
Chris Mine-94 SR5 4-Runner, 3.0, 4X4, Aisin Hubs, Yakima Load Warrior, 210k Miles | Wifes-99 Limited |
#15 (permalink) | |
Quote:
#16 (permalink) |
Sounds like the exact same thing on my 84 Camry engine-2SE motor. I usually change the oil after letting my car sit overnight. The oil filter is always empty. That way, I don't make a mess. If I run the engine and let it set for about 2 hours, it will be empty too. Any less than that and oil will spill out when I unscrew the filter.
I don't worry about it any more. The car has almost 260,000 miles on it and still doesn't use oil between oil changes.
__________________
Nic 1997 Tacoma 4X4 Xtra Cab 2.7L 5 speed |
| Tags |
| 22re, empty, filter |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| oil filter relocation kit for the 22re | van7559 | 86-95 Trucks & 4Runners | 5 | 12-16-2006 07:18 AM |
| Oil filter for 3.4 and 22RE are the same?!? | Tacoma Dude | General Vehicle Related Topics (Non Year Related) | 11 | 11-26-2005 08:28 PM |
| 22RE Oil Filter Problems | kryptik | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 07-26-2005 04:47 AM |
| Air Filter & Oil Filter -best $? | FirstToy | Maintenance & Repair Archives | 3 | 02-11-2004 07:36 AM |
| any one use a different filter oil with amsoil air filter??? | swerks | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-07-2003 08:56 AM |
