Oil filter concern
Oil filter concern
I have read several posts about oil filters as far as this one is better than that one. I presently own a '93 4Runner and a '95 ext. cab , both with 3.0 V-6. I have used factory filters so far with both trucks over 100,000 miles on each. Is there a better filter to use ? If so please inform , I'm always open to new ideas. THANKS
OEM filters are the way to go. Some say that Napa makes good ones as well. Amsoil works well with others. If you've used OEM so far then I say stick with what got you there... but most of all stay away from Fram.
Regular oil changes is most important. I've seen toyota's run over 1/4 million miles on frams with zero engine problems. Personally, I'm sticking with toyota filters. They're cheap and effective.
jasonty
41
12-23-2018 01:00 PM
