oil cooler cause overheating??
Old 12-28-2011, 03:54 PM
mustangroady's Avatar
i have a 1998 4runner that is over heating and i can not find out why. I have already tried all of the logical things to do , but was wondering if the oil cooler line on the water pump housing could cause the engine to overheat??
Old 12-28-2011, 04:43 PM
rworegon's Avatar
Cannot remember ever hearing that the oil cooler caused the overheating.
What have you done so far?
Old 12-28-2011, 04:58 PM
cpizzle42's Avatar
Please list things you have replaced and go into greater detail about your overheating issue so we can help you.
Probably not the oil cooler, they are a simple design that works pretty darn good.
Old 12-28-2011, 05:23 PM
So far i have replaced the head gaskets, water pump, thermostat , radiator hoses, radiator, fan clutch , checked the timing, burped the system . All of this is done on an engine with less than 100 miles on the rebuild ( never could find out the overheating issue since rebuilt). It acts like there is something blocking the coolant , or the thermostat isnt opening but i have tested 2 thermostats and they are both fine. Also i ran the vehicle with a gutted thermostat and it did not overheat while driving ( actually the temp. of the engine went down ).
It only overheats when driving, and can run all day without overheating while the 4runner is in park.
The 4runner has 259,000 miles
Old 12-28-2011, 05:36 PM
rworegon's Avatar
How are you determining its overheating? If you are just going by the dash gauge, the temp sender may be just giving a high reading.
Did you replace the radiator cap too? A cap that does not let the pressure build to the proper PSI causes the coolant to boil at a lower temperature.
When you replaced the head gaskets, did you take the heads into a machine shop and have them checked for flattness and pressure tested for cracks?
Old 12-28-2011, 05:49 PM
I am going by the dash temp. gauge , but if you can see the change in temp. from the gauge i would figure that it would work fine ( when i put the gutted thermostat in it i watched the temp gauge go from 1/4 all the way to the C and thats while driving it for about 10 minutes)
I will see about the radiator cap but it seems like it is acting fine ( no fluid spewing out of the radiator and after driving it has pressure built up )
Old 12-28-2011, 07:03 PM
rworegon's Avatar
Unfortunately, the temp gauge is not a very accurate way to determine overheating. Mine stays right in the middle. Is the temp gauge shooting up into the red? Are you boiling over?
You might try using a 1" dial thermometer in the radiator neck and get it submerged in the coolant and see what you are heating up to at the top of the radiator.
Old 12-28-2011, 07:21 PM
I have never let the temp gauge get pass 3/4 of the way up because i dont want to blow a head gasket, and no it is not boiling over.
Also i think the thermostat is not opening up causing it to overheat ( but i have test the two oem thermostats that i bought and they open up fine). That is why i am leaning toward it being something to do with the oil cooler cycling the fluid through , not letting the thermostat open
I know in a Subaru that if you clamp the heater hose down it will cause the engine to overheat , having the exact symptoms my 4runner is showing
Old 12-28-2011, 08:31 PM
enapa's Avatar
Headgasket backwards? That was my issue..... God im dumb.... When it overheats rev it real quick pretty high. Does it cool down when you do that then warm back up?
Old 12-29-2011, 06:30 AM
suncomb1's Avatar
Take your thermostat out. There is a small bypass hole with a pin in it. Remove the pin and drill the bypass hole out using a 1/4" drill. Re-install the thermostat. Start the engine and let it warm up. If the engine over heats then most likely you have an internal engine problem or bad water pump. Do you have any water vapor exiting from the exhaust? I modify all of my thermostats this way on my street rods, customs, etc. I have never had an engine overheat.
Old 12-29-2011, 07:26 AM
93toyrunner2's Avatar
Be sure to install the thermostat with the drilled hole in it positioned at the top, at 12 o-clock position.
Old 12-29-2011, 10:34 AM
thanks for the information i will try this sometime this weekend and get back with you on what it does. the water pump is brand new , and i do not think i have any water vapor from the exhaust but i will check it when i get the 4runner back together.
Old 12-29-2011, 04:06 PM
rworegon's Avatar
Link to enapa's thread with post 54 below being his solution for similiar problem after HG replacement:
https://www.yotatech.com/forums/f2/9...91/index3.html
Originally Posted by enapa
Well i gutted the cat and that didnt fix it. So the only thing left? You guessed it. I actually put the head gaskets on the wrong side, drivers side on passenger and vice versa. Let this be a lesson to everyone....take your time and dont let anyone rush you. I feel like such an idiot. I just got the chance to tear down and i could tell it was wrong immediately. Cometely blocked holes. So for anyone having issues after head gasket change if your rig overheats only when driving and cools back down briefly when you rev the engine real hard then chances are your head gasket is backwards. On the brightside i now feel like a pro at doing this lmao. So if anyone ever wants any pointers send me a message and i will try my hardest to help you through it.
Old 12-30-2011, 12:31 PM
DailyDrive's Avatar
An ODBII graph of the warm-up and driving around could tell a lot...
Old 12-30-2011, 03:59 PM
enapa's Avatar
One quick way to check on hg is to lay under drivers side just behind tire and look up to where the heads connect to the block. You should see a big L on corner of gasket. Wish i knew that before lol. If you cant see it try to reach up and clean it off. There should be an L. If theres not big sign hg are on wrong side.
Old 01-01-2012, 08:16 AM
It turns out that my new fan clutch isnt working, so i replaced it and fixed the problem
thanks for all the help
Old 01-01-2012, 02:17 PM
rworegon's Avatar
Great news that you found the problem. Luckily, swapping the new, but bad, fan clutch is quick and easy. Mind sharing where you picked up the one that was no good?
Old 01-01-2012, 07:17 PM
enapa's Avatar
Sweet. Easy fix.
the1998sr5
15
07-14-2020 08:35 PM
this_guy
07-31-2015 01:27 PM
Jeffreynmandy
07-18-2015 08:26 AM
the1998sr5
07-16-2015 06:20 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: oil cooler cause overheating??
