Oil in Bellhousing?
Old 06-10-2009, 04:05 PM
cchinny's Avatar
Oil in Bellhousing?
Changing my clutch and I have lots of oil in my bellhousing. Evenly spread with a big pool back by the trani. Is there a trani seal? The rear main looks okay, but I can't be sure. Any ideas?
Old 06-10-2009, 04:21 PM
iamsuperbleeder's Avatar
'tis an input shaft seal on there
not 100% sure on the process of replacing it, BUT I'll be doing mine soon since my motor's out for rebuild
My mess IS from the rear main though; I'm just going to replace the trans seal as assurance, so I don't have to separate the motor and trans later just to replace a $5 seal, lol
Old 06-10-2009, 04:26 PM
cchinny's Avatar
Mine looks a lot like yours but with a lot more oil. Did you have oil on your clutch or flywheel? I heard it spins too fast to get on there even though it may be the rear main seal. How can you tell if the rear main is bad?
Old 06-10-2009, 04:31 PM
waskillywabbit's Avatar
Rear main seal I bet.
Question is: Is it motor oil or ATF? That would tell you what is leaking.
Old 06-10-2009, 04:32 PM
Ron's 85's Avatar
sounds like your rear main to me. it's only gunna leak when the motor is running.
Old 06-10-2009, 04:53 PM
the clutch wasn't coated like the bellhousing, but there was a thin layer all over everything accept for the friction surfaces
Old 06-10-2009, 05:43 PM
DudeBud's Avatar
ATF in a toy manual trans? it should be 80w-90w.
you can tell the difference between motor oil and gear oil by the smell.
Old 06-10-2009, 05:47 PM
space-junk's Avatar
i know that we are already answering his questions, but just saw, hes in the wrong forum... lol...
Old 06-10-2009, 05:49 PM
DudeBud's Avatar
why is that?
Old 06-10-2009, 05:57 PM
cause he has a 96 Taco
I hadn't noticed untill you said that
oh well, lol, same thing applies, the picture I posted just might be a little different
Old 06-10-2009, 06:06 PM
Yeah, what he said. It has been a long day.
Old 06-10-2009, 06:12 PM
DudeBud's Avatar
oh just because his sig says he has a 96 taco doesn't mean he's working on one right?
take another look at the pic diff on the wrong side. you should know its not a taco but a 86-95 ifs truck or 4runner.
Old 06-10-2009, 06:13 PM
OP didn't post the picture.
Old 06-10-2009, 06:17 PM
DudeBud's Avatar
ok its been a long day for me to
Old 06-10-2009, 06:24 PM
RMA
RMA's Avatar
Hahahahah , Long day for everyone huh !
Old 06-13-2009, 06:23 PM
cchinny's Avatar
Thanks for all the advice. It is actually my 89 4runner I'm doing the clutch on. Did the rear main seal today. I didn't do the gasket that goes behind the seal cover. Is this necessary? Icouldn't get it off despite the oil pain bolts out and the 5 bolts in front. Also, how hard is it to do the front seal on the trani in case in case that is where the oil is comiing from? Last question, how do I know which way the clutch disc goes in...does it matter? Are the scallped edges supposed to face a certain way?
Thanks!
calderp
Engine Swaps
08-16-2016 05:15 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Toyvana
07-29-2015 10:47 PM
yourrealdad
07-29-2015 11:08 AM
calderp
07-27-2015 09:58 AM
Quick Reply: Oil in Bellhousing?
