offroading mess up your alignment?
well can offroading mess up your font end allignment? cause it looks like i need one all of a sudden after i went offroading about 2 weeks ago.
Mine's fine. I haven't had an alignment in probably 5 years and it tracks straight and the tires wear fine. I'd say as long as you take it easy and don't jump it, the alignment should be fine.
I just re-read my post and it's a little misleading. What I meant to say is that mine has been fine after off roading, but yours might need an alignment. I don't know, did you hit something hard? When was your last alignment? Is your tire(s) wearing funny? What are your symptoms?
Not yet, thats one of the things I love: slow crawling on some crazy trail, then smooth on the freeway at 80+
It makes me hesitant to lift it and lose the nice freeway ride, I'm already hitting some decent trails with stock setup, maybe just need some sliders
I don't know which gen 4Runner you have, but my 2nd gen has 1 alignment in the past 5 years and still tracks true and has no significant tire wear. It's averaged a couple of trips a month, dirt roads, trails, and rough trails, but no rock crawling.
Maybe you just need to get it set correctly.
Or
If it's a 2nd gen, you might need your idler arm replaced (I'm on my 3rd).
Or
when i hit something hard my alignment was still good but my steering wheel had to be turned like 60 degrees and that was straight... just used a steering wheel puller, pulled it off, and put it back on and its pretty good
kelly
kelly
no i haven't hit it very hard at all. i don't know when it had its last alignment because i just bought it like 2 months ago. and it only seems to have noticable wear on the inside of the drivers side tire. yeah its a second gen 94. and it doesn't ride rough at all or anything. i guess i'll just take it to les schwab today and see what they say it is. i hope it isn't the idler arm. well thanks everybody.
hiluxinargentina
09-30-2015 11:12 PM
33, alignment, alignments, allignment, allingment, crawling, hitting, inch, mess, messing, muddin, offroading, roading, rock, tires
