OEM Temperature Gauge - Flat Spot - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-08-2005, 08:13 AM   #1 (permalink)
I have a 1995 Tacoma. Regardless of ambient temperature and driving conditions, the OEM temperature gauge never moves from center. I know from owning other cars that engine temperature can fluctuate greatly even in a properly working cooling system. I have a 1997 Land Cruiser and I noticed this same behavior on the Land Cruiser temp gauge as well. I spend a lot of time on the Land Cruiser Website (IH8MUD.com), and the guys there looked into it and found out that Toyota installed a "zener diode" on the temperature gauge to give it a "flat spot", so the gauge stays stable at any temperature between 190 and 230. The gauge only starts to head north when the engine temperature exceeds approx. 230 degrees. See thread for modification here:
http://forum.ih8mud.com/showthread.p...perature+gauge
After a LOT of experimentation it was finally determined that this very inexpensive mod will fix the OEM gauge by replacing 2 diodes in the temperate gauge with diodes you can buy in Radio Shack for about $2.00.
My question is has anyone noticed and or discussed this "flat spot" on their Tacomas / 4Runners? Has a mod been develpoed to fix this? Does anyone think the mod would be the same? I realize that an aftermarket gauge can be installed, but I see no point in installing ANOTHER gauge in place of the OEM gauge that should be workng properly.
The floor is open for discussion.
__________________
1997 Black Land Cruiser with Lockers.
1990 Triple Black RX-7 Convertible TURBO
1995 White Tacoma with Reg. Cab and 3.4L V6
Philly72 is offline
Old 11-08-2005, 08:34 AM   #2 (permalink)
mt_goat's Avatar
Good idea, I wonder if the LC gauge mod would work on our gauges? BTW do you have a 95.5 Tacoma or a 95 pre-tacoma truck?
__________________
Dale
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 11-08-2005, 09:37 AM   #3 (permalink)
My truck is a 95.5. If it wasn't it wouldn't have the 3.4L, it would be a 3.0L.
__________________
Philly72 is offline
Old 11-08-2005, 09:45 AM   #4 (permalink)
mt_goat's Avatar
Quote:
Mine is a 93 but soon to have a 3.4L
__________________
Dale
mt_goat is offline
Tags
gauge, tacoma, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Outside Temperature Gauge black runner The Classifieds GraveYard 3 12-28-2006 01:31 PM
Flat spot? HarrisonP 95.5-2004 Tacomas & 96-2002 4Runners 4 03-07-2005 03:36 PM
Flat spot at 3000 rpm robbieracer 95.5-2004 Tacomas & 96-2002 4Runners 8 10-23-2003 08:34 AM
temperature gauge reading ckgoobs 95.5-2004 Tacomas & 96-2002 4Runners 4 01-26-2003 06:54 AM
2009 InternetBrands, Inc.
