OEM Swing Out Spare Tire Carrier? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-20-2007, 12:15 PM   #1 (permalink)
Midget96's Avatar
I was searching around for some info on a KZN185 1KZTE swap, and came across this:
http://www.todoroki-trading.com/stoc.../stock006.html
I've never seen a rear tire carrier that was Pathfinder-style for the 3rd gen. Anyone have any details about this thing? I think it's a great compromise to an expensive rear bumper that's built around a swing out carrier...
Midget96 is offline
Old 04-20-2007, 12:58 PM   #2 (permalink)
SOAZtim's Avatar
Ohh. Heres a bump for this. I want to find out too. When I was in Japan I saw a bunch of 4runners with these, but I never thought about finding a part #
__________________
2001 4runner. 255/85/16 BFG KM, A-trac/VSC disable switch. DR coilovers. OME rear springs with bilsteins, 4.88 gears with ARB lockers. Waeco CF-50 fridge. Home made sleeping platform with drawers. Home made rear bumper. Home made sliders. Blue sea fuse box. ICV8000 Icom 2meter. Uniden CB in ashtray. Donaldson Top Spin pre-filter with home made snorkel. TJM front bumper with m8000 and syn line. Baja Rack Mega Mule roof rack. Lowrance. 7" hid's. Lots of scratches.
www.soaztim.com
SOAZtim is offline
Old 04-20-2007, 01:10 PM   #3 (permalink)
914runner's Avatar
I would assume it installs like the 2nd gen. one, which has a brace on the inside of the body that you have to weld in. You also have to cut out some of the body on the inside to put the tire carrier brace in, and then re-weld the inside body part back in. A lot of work.
Chris Geiger did it on his old 2nd gen. but the article isnt up anymore.
http://toyota.off-road.com/toyota/ar....jsp?id=186335
914runner is offline
Old 04-20-2007, 03:29 PM   #4 (permalink)
Midget96's Avatar
That doesn't sound too bad, and if it was less than $1500 all said and done, then I'd do it. From the issues I've seen with bumper mounted carriers (bearing failures), I think this is a solid choice. Hell, the bracing might even already be there...
I'm sure some JDM-exploiting-importer could get a hold of these things without much fuss, too.
Midget96 is offline
Old 04-20-2007, 04:26 PM   #5 (permalink)
914runner's Avatar
From what I have read, you wouldnt want to mount anything larger than a 33" on these carriers, they just arent super strong. A 33" might be pushing it too.
Old 04-20-2007, 09:09 PM   #6 (permalink)
fireteacher's Avatar
1500 will get you a fabbed rear bumper and carrier! i know you have read issues on bearing failures but did they have the best types of bearings in them? what caused them to fail? to me it looks like a blazers swing carrier. go custom!
__________________
Shaun
99 limited 4runner 3.4L
MODS: TJM-17/Sonoran shackle hangers/driving lights - DIFF Breather - Sliders - Cobra 19 ULTRA III cb and 3ft. Wilson ant - 265/75/16 Definity Dakota A/T - "SATOSHI MOD" - All Weather Mats - Locker Mod - Fog Light Mod - Vortex Classic Muffler
My profile http://yotatech.com/showthread.php?t=96117
fireteacher is offline
Old 04-20-2007, 09:44 PM   #7 (permalink)
Midget96's Avatar
The stock 265/70/16 Michelins run 41 lbs./each. I run 255/85/16 BFG MTs, and those are 53 lbs. Even a 285 is only 15 lbs. heavier than stock. I would think that this carrier would have no trouble handling the ~10 lbs. more...
Quote:
I should have been more clear. I'm not trying to spend anywhere near $1500 to get a tire carrier, and I know that's the ball park of a custom bumper/carrier. If I could utilize the OEM carrier for 1/3 of the price of a custom piece, I think it would be worth it. Again, I have no idea on the price or labor to install one, I'm just theorizing...
All the one's I've seen with bearing issues used nice needle roller bearings. But in my eyes, the custom bumper focuses the weight of an 80 lb. wheel/tire, a heavy steel carrier assembly and possibly a 40 lb. Hi-Lift all on one pivot point. The OEM carrier clearly distributes the weight better and has the potential to be cheaper.
Midget96 is offline
Old 04-21-2007, 07:22 PM   #8 (permalink)
Starbuck3733T's Avatar
Send a message via AIM to Starbuck3733T
subscribed!
would the toyota japenese FSM have the part # for the carrier?
__________________
Trust me, I'm an engineer.
2002 4Runner 5VZ-FE 61K Limited 4WD
Now: Kenwood CD Head + Custom iPod interface, Pheonix Gold M50 amp + JL 12W0 sub, Mobile 1 synthetic, napa gold oversized filter (FIL1516), ISR mod, running boards = !buhleted!
Sooner: Deckplate, bigger mudders: 32? 33?
Later: 1.5" body lift, 2.5" suspension lift of some variety. (undecided)
SigSauer P229 .40 S&W Equipped!
RIP 1994 4Runner SR5 5spd MT, 31x10.50 Dunlop Mudders, 186K 3VZE blown engine.
Starbuck3733T is offline
Old 04-23-2007, 02:33 PM   #9 (permalink)
Hilux
According to the currency converter I used, that Hilux is less than $8,00. I wonder what importing would run?
brazos609 is offline
Old 04-23-2007, 02:45 PM   #10 (permalink)
olharleyman's Avatar
I have one on my second gen and you will also need a different tailgate or fab your existing one for back up lights on the outside of licence plate mounting point as it is. Where your plate is now you would have to mount the catch for the swing out and move your plate lights to the right over the new plate hanger on the swing out. I carry a 35 B.F.Goodrich on a micky thompson with not weight issues at all on it so i dont think you will have much issue with the weight of your spare. Just a little fyi
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift 6" coils rear
Aussie Locker front
5.29's Front And Rear
35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels
Super Charged 3.4 on the way
1993 SAS 4runner 22re 5 speed
4" front 5"rear
5.29's
35 x 12.5 BFG KM'S
Dick cepek DC 1's
88 stock 4runner
3.0 auto
for now
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
1998 Harley Custom Dresser
107 rwhp
139 ft.lbs.trq.
olharleyman is offline
Old 04-23-2007, 03:28 PM   #11 (permalink)
Kinda cool. I'm guessing your spare doesn't fit underneath? IMO the good quality spare tire carriers are going to be much stronger. Tied to the frame as opposed to the body. It really depends on the quality of the fab work. I've seen diesel powered welders (HEAVY) mounted on swing out bumpers that stay put. These are on 1ton's not a 4runner. The heavy bushing type carriers are much better than the ones made from trailer spindles. They seem to handle 38's and larger on landcruisers without problem.
I guess i'd say that's a unique carrier. It'd be different, but I don't think it would be any better. If your spare is to big to fit underneath, it should probably be on something tied to the frame. Plus it would be one more thing to move before getting into the back. It would free up some room for an air tank or aux fuel tank under there though, but I don't see many third gens with Yorks or comparable compressors that would put that big of a tank to use.
That tire rack would probably be a cool way to put a highlift and a gas can or two on with a factory look. I wish I had that surf!, I'd be using diesel cans...
__________________
96 Limited
wheeler: 75 fj40 38's... ect.
jetboy is offline
Old 04-23-2007, 05:26 PM   #12 (permalink)
SOAZtim's Avatar
I was looking at it as a piece I could put on before epic trips. Keep my spare underneath and put one on the back as a back up
__________________
www.soaztim.com
SOAZtim is offline
Old 04-24-2007, 08:27 AM   #13 (permalink)
techno's Avatar
Here's some pics with Part Numbers for the factory tire carrier. These were posted somewhere else on this forum but I cant remember where.
There is alot of work to do to add these....
__________________
00 4Runner SR5 4x4
techno is offline
Old 04-24-2007, 09:14 PM   #14 (permalink)
KZN185W's Avatar
I got a BFG MT LT285/75R16 Load Range D on my stock spare tire carrier and it doesn't show any sign of distress, nor has the body. The bushings on the upper arm needs to be replaced to as it rattles when I go fast over uneven surfaces on the road.
__________________
1996 Pearl White Hilux Surf KZN185W SSR-G l 3.0L TDI l Dual Battery l LT285/75R16 l Recaro Seats
Drive Your Dreams
KZN185W is offline
Old 04-26-2007, 11:44 PM   #15 (permalink)
I have a 33x12.50 on a stock rim and it fits okay, and although it is way heavier it still hasnt given me any problems.
__________________
1990 4runner SR5 V6, 3" BL, 2.25" Flowmaster, 33x12.50x15 (current)
!998 Honda Civic-Cold air intake, Catback exhaust, Light weight power pulleys, DC headers, short throw shifter, aftermarket spark wires, and plugs (sold)
1995 Buick Skylark (sold)
1991 Mitsubishi Mighty Max (sold)
1957 Ford Fairlane 95% restored (sold)
first4runner is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
New Swing-Out Rear Spare Carrier for 4Runner?? ProMed 03+ 4Runner/GX470, & 05+ Tacomas 3 02-08-2007 06:00 PM
How to affix a swing-away tire carrier to 4Runner? Naphtali 95.5-2004 Tacomas & 96-2002 4Runners 3 10-02-2005 05:31 PM
to swing-a-way or NOT to swing-a-way with the tire carrier? amorphous The Fab Shop 15 09-08-2005 07:23 PM
Is A Swing-Out Tire Carrier Worth It? Roadrunner 95.5-2004 Tacomas & 96-2002 4Runners 28 10-07-2003 09:38 PM
Rear Spare Tire Swing Mount bucky23111 95.5-2004 Tacomas & 96-2002 4Runners 8 10-16-2002 06:37 AM
2009 InternetBrands, Inc.
