OD issue, I have 2 part numbers and dont want to order the wrong parts! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-15-2005, 07:06 AM   #1 (permalink)
Ilovemountains's Avatar
Question OD issue, I have 2 part numbers and dont want to order the wrong parts!
OK I just got off the phone with the stealership, they say the part I need is called a Water Temperature Sensor pn/ 89422 12010 but after doing more searching here I found this post http://www.yotatech.com/showthread.p...erature+sensor which calls it the temperature switch with the pn/ 89428 89101 is it possible this is the same part? Im going to flush the tube like this post says because when I changed my thermostat last week there was a bunch of black rubber gasket crap in the thermostat housing which could be the main cause of my OD issue, may not even need a sensor after all! Any help with these part numbers would be GREAT! The stealer wants $70 for the first part, I dont know what I need at this point!
__________________
88 3.0 XCab, K&N fipk, Borla cat-back,Magna Flow Cat, Downey frame brace, Downey 2" rear springs, BJ spacers, Aisin manual hubs,B&G Fiberglass bed, extended diff. breathers, Bilstein HD shocks, Rancho RS5000 stabilizer, Brembos & TRD Pads, Revos, Hella 500s, 4 runner bucket seats and console ETC ETC...
Ilovemountains is offline
Old 11-15-2005, 07:14 AM   #2 (permalink)
I looked these up onlin
It looks like the dealer PN 89422-12010 is for the gauges but Im not sure, the 89428-89101 pn just comes up as the temperature switch.. ARRRGGGHH I really wish I had a 5 speed, this is starting to get old
__________________
Old 11-15-2005, 07:20 AM   #3 (permalink)
Doc279's Avatar
Quote:
I've had this same problem for several years now - I changed the temp sender and cleaned the manifold of the black rubber looking pieces. My OD works fine in the spring and summer months - late fall and winter seems to either shift to OD slow or not at all. It has to do with temperature but I have not completely fixed mine. Watching this thread closely !!!!
__________________
"Life's to short !!! Let's drink a couple - cold beers !
1985 4 runner - pretty much stock but it kicks butt stock !!!!!!!!
30" bridgestone duellers on black steelies.
More to come !
Doc279 is offline
Old 11-15-2005, 09:46 AM   #4 (permalink)
Question How to test / jump the sensors into tricking the AT into shifting into OD cold???
OK I read some where that you can just un hook the temp sensor and the trans will shift into OD, not true. I just went home at lunch and first un plugged the temp switch "I think/hope".. If you climb up on top of your engine there are 3 sensors in a row behind the intake, according to the book the far left is the temp switch, the middle is the sensor. The switch is a 1 wire sensor, I first un plugged it and went for a quick drive, nothing. I drove home and plugged it back in and un plugged the sensor which is a 2 wire unit, I drove the whole way back to work with no OD..... To trick the ECU into thinking the engine is up to temp would you just jump the 2 wires leading to the sensor? I’m still not sure which one works with the trans, the dealer is no help at all, the Toyota books are no help and I keep finding info on both parts, I’m tempted to just change both but really don’t want to drop $200 on sensors if I don’t even know which one could be bad!
__________________
Old 11-15-2005, 11:05 AM   #5 (permalink)
Anyone?? Anyone know of another resource that could help me out with these sensors?
__________________
Tags
01, 4runner, 84, 8942212010, 8942212010000, bg, camry, ect, fiberglass, issue, od, part, replacement, sensor, temp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Part numbers for NLA parts paxil4x4 General Vehicle Related Topics (Non Year Related) 2 03-18-2007 05:48 PM
Where do you get part numbers from? tomasp General Vehicle Related Topics (Non Year Related) 8 09-08-2006 08:12 AM
I need a part number for a part I dont know the name of!! CynicX 95.5-2004 Tacomas & 96-2002 4Runners 5 10-01-2005 09:06 AM
Wrong Order from Summit hill 95.5-2004 Tacomas & 96-2002 4Runners 14 05-11-2005 11:27 AM
Looking for Part Numbers Albuquerque Jim 95.5-2004 Tacomas & 96-2002 4Runners 5 07-16-2003 08:02 AM
2009 InternetBrands, Inc.
