OBDII code P1780 - YotaTech Forums
Go Back   >
OBDII code P1780
LinkBack Thread Tools Search this Thread
Old 11-11-2006, 12:54 PM   #1
OBDII code P1780
I have a 95 4runner with a 99 3.4 and am getting a P1780 trans control switch (O/D cancel) out of self test, code. Any idea on what I need to do to fix this?
Thanks
yellowvwthing is offline   Reply With Quote
Old 11-11-2006, 01:43 PM   #2
WATRD's Avatar
P1780
(DI–261)
Park/Neutral Position Switch Malfunction (Only for A/T)
 Short in park/neutral position switch circuit
 Park/neutral position switch
ECM
2 or more switches are ON simultaneously for N, 2, L and R position (2 trip detection logic)
P1780
When driving under conditions (a) and (b) for 30 sec. or more
the park/neutral position switch is ON (N position):
(a) Vehicle speed: 70 km/h (44 mph) or more
(b) Engine speed: 1,500 – 2,500 rpm
ECM
WATRD is offline   Reply With Quote
Old 11-13-2006, 07:48 AM   #3
Is there anyway to bypass the switches in order to pass smog for now? If the tach is not working could it cause this code to come up?
Old 11-13-2006, 09:40 AM   #4
WATRD's Avatar
What you see listed above is from a factory service manual. So, if it's not listed, then Toyota doesn't think it will cause this problem.
It's not as easy as "bypassing switches" since there is position detection logic run over multiple trips.
Just fix it. The switch is probably just out of adjustment.
Old 11-13-2006, 10:53 AM   #5
Thanks for the reply. I tried adjusting the switch on the tranny and checked the switch on the shifter, no luck. The strange thing is the light will not come on till you have started the car and put it in gear and then turned it off and restarted it and put it in gear a second time.
Old 11-13-2006, 11:07 AM   #6
WATRD's Avatar
That's the multiple trip detection logic we were talking about it. Believe it or not, Toyota doesn't want to bother you with "Check Engine" or "Malfunction Indicator" lights unless they have a good reason to do so. So, many of the OBDII systems require more than one "trip" with a failure to light the lamp. On this one, it requires that the failure be detected twice under certain prescribed conditions.
Here's the diagnostics page from my rig if you want to dig into it more. I suspect the diagnosis section would be similar for yours, even if the wiring diagram is not.
http://www.watrd.com/work/cip1780.pdf
Knock Sensor replacement 3vze moparbay 86-95 Trucks & 4Runners 5 10-06-2015 10:24 AM
HELP! 89 4Runner 22RE Auto, no injectors! bradahman 86-95 Trucks & 4Runners 8 10-01-2015 10:24 AM
Advice on a possibly bad 2TR-FE and shady dealer. charlie_fong General Vehicle Related Topics (Non Year Related) 0 09-27-2015 11:06 PM
Questions- Housing & Diff install- 1989 2wd 8 inch where 1991 2wd 7-1/2 was Odin 86-95 Trucks & 4Runners 3 09-26-2015 07:56 PM
Oil catch can installed, now cel p0171 Draven023 Newbie Tech Section 3 09-26-2015 01:41 PM
Tags
1780, 2001, 98, at, average, car, code, cost, diagnostic, malfunction, obd2, only, p1780, parkneutral, position, switch, tacoma, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
