o2 sensor
Old 09-08-2005, 06:51 PM
pitm96's Avatar
o2 sensor
quick question- if an 02 sensor is bad- will the engine run rich? what about if there is an exhaust leak before the snesor? will excess gass be pumped into engine? thanks- 1994 pick 3.0 v6
Old 09-08-2005, 08:40 PM
colsoncj's Avatar
if there is a leak before the sensor, it will lean out what the sensor sees, causing the motor to run rich. if the sensor is bad, usually the computer defaults to a "one-size fits all" configuration which i believe is on the lean side.
moparbay
03-10-2023 03:50 PM
jb451
7
10-07-2022 06:58 AM
Kreedy1
09-08-2015 06:33 PM
zz_denis
09-06-2015 03:43 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: o2 sensor
