Notchy Steering - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-26-2009, 10:04 AM   #1 (permalink)
AppleJack's Avatar
Notchy Steering
I searched but nothing seemed to match my issue. When cold, as in the vehicle itself, my steering feels notchy in the wheel right after I back out of my driveway, put it in D and take off. It goes away right after that.
It feels like and old worn out farm truck for a moment, but so far it does not last. I have not noticed any leaks, and the fluid looks good and is full.
I've only had this rig for 3 days. So I cant say how long this has been happening.
__________________
Fires, Friends, and Books Decree
Wisdom, Strength, and Controversy.
To believe with certainty, one must begin doubting.
AppleJack is offline
Old 12-26-2009, 02:26 PM   #2 (permalink)
Yota Runner's Avatar
I think I was having the same thing happen to my rig. I think it has something to do with the power steering fluid being cold. Since it has warmed up a little I haven't noticed it anymore. Mine was only doing it when going really slow or stoped and when the steering wheel was between about 75-100 percent turned. If anyone else has anymore insight post up too.
__________________
98 4 Runner SR5 3.4 V6 - Anthracite Metalic - 5 spd - 265/75/R16 BFG AT's on Akuza 359 wheels - Trail Gear 60" Rock Sliders - Rola Roof Rack - Custom Front Recovery Points - Hella 500 fogs - Flowmaster 50 series - Clear lenses - 5% tint - GT covers Exact fit seat covers - DVD - Silverstar ultra's... It'll grow up... someday....
Yota Runner is offline
Old 12-27-2009, 01:52 PM   #3 (permalink)
AppleJack's Avatar
Took it on some mild trails (tires are more street biased) on now the steering squeals at full lock. Is this a rack problem?
__________________
Old 12-28-2009, 03:12 PM   #4 (permalink)
Tragic Drive's Avatar
Belt tension maybe..
__________________
,Thomas
Supercharged 3.4 in a ARB Locked 95 Runner
Tragic Drive is offline
Old 12-28-2009, 03:55 PM   #5 (permalink)
brian2sun's Avatar
I doubt it's your rack. Racks will usually leak before they go bad (at least from my experience). Seeing as it is a new truck to you, I would flush the p.s. system or at very least see if the fluid is red ATF.
You'd be surprised how many people put power steering fluid in there when you're supposed to use Dexron ATF. I'm also talking about my 3rd gen 4runner - I'm not hip to the newer Tacos/runners. From your avatar it looks like you have a 05+ Taco, but then again we are in the 95.5-04 section. Ah hell, just read your p.s. cap and make sure it's the right fluid.
__________________
'97 4Runner SR5 3.4L 4x4 * 200K Mile Club * Trail & Snow Rig
3" Suspension Lift - 883s/891s, 1" 4Crawler BL, OME Comfort Shocks, 255/85R16 Bighorn M/Ts on 16x7 (4" BS) Cragar Soft 8 Wheels
Rear ARB Locker , 4.88s, Sliders, ARB Bullbar, CBI Rear Bumper w/ Tire Carrier (on the way), No Sway Bars, No ABS
'05 Honda CR-V 2WD LX * 29+ Hwy MPGs * D.D.
brian2sun is offline
Old 12-28-2009, 05:32 PM   #6 (permalink)
my front end started feeling loose..................check your lower control arm bushings.
I raised my runner and the lower control arms are shaking like a leaf in the wind when I move the wheels left to right.
Not to mention the alignment being out of whack from the worn bushings.
Kenny S
sharrack is offline
Old 02-03-2010, 08:05 PM   #7 (permalink)
atf additive in power steering?
Applejack - mine is getting notchy too. I drained the power steering i'd put in before I knew better and put in ATF and it got much better. Every 3000 or so it gets notchy and I use a baster to draw out fluid and put in new atf and it gets better for awhile. It's worse on cold days. Anyone know if an auto trans additive in the atf power steering fluid would help?
__________________
1996 4Runner Ltd 190k+ miles
1989 Toyo 4x4 Pickup 250k+ miles - sold
1967 GMC pickup
Ford Taurus company car - borrring
to many motorcycles to count
hpctoy is offline
Old 02-03-2010, 09:59 PM   #8 (permalink)
96743runner's Avatar
Quote:
I had the same problem a while back and it turned out to be a worn power steering belt. I had it changed and no noise at all on full lock now. I would suggest having that changed.
__________________
1998 4Runner Limited Desert Dune 3.4 4x4 A340F (No. 439 off the assembly line on 11/97!) - Currently around 66k - with a few mods
2010 Tacoma Access Cab Black Sand Pearl 4.0 V6 4x4 TRD Off Road <1k miles
96743runner is offline
Old 02-20-2010, 01:51 PM   #9 (permalink)
AppleJack's Avatar
Well for now I will remove whatever is in there and put in some ATF but if it pops up again I'll just change out the pump.
Thanks for the help guys.
__________________
Tags
feels, ford, notchy, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2010 InternetBrands, Inc.
