Noisy U-Turn
Old 08-30-2004, 09:02 PM
AF93pickup's Avatar
Noisy U-Turn
Anyone know what the annoying creek and moan noise is when I make a sharp u-turn in my 93 pickup? My 84 pickup did the same thing and I believe my dads 88 runner does it too. I can not figure it out. Any hints on how to fix it would be much appreciated.
Old 08-30-2004, 09:09 PM
desert whomper's Avatar
try replacing the bushings on ur leaf pack? im not sure if this oculd be it but i know they can squek
Old 08-30-2004, 09:16 PM
superjoe83's Avatar
this is a pretty common problem, when your wheel is turned all the way it is against a stop bolt, which had a plastic cap from the factory, but those tend to wear through and fall off, the sound that you are hearing is the bolt rubbing your control arm, putting a little dab of grease on the bolt head will help, try a search this has been talked about before
Old 08-30-2004, 09:39 PM
EWAYota's Avatar
yep, superjoe's on the money. a little grease on the bolts, i lube the bolts and the point of contact everytime i change the oil and lube the zerks.
Old 08-31-2004, 11:00 AM
DavidA's Avatar
I bought the bolt caps and use grease also...works great. I hate that grinding sound.
Old 08-31-2004, 11:59 AM
havic's Avatar
Does anyone have pics of where the caps belong and where to apply grease?
JNapolitano
11-14-2019 07:46 PM
dbollier123
09-29-2015 05:23 PM
ac7822
09-11-2015 08:49 AM
Jboy
06-16-2004 08:58 AM
Quick Reply: Noisy U-Turn
