Noise when turning
Old 07-16-2003, 06:37 PM
Fink's Avatar
Noise when turning
It's weird, I was just out on my land doing a little 4 wheelin and noticed something. When I turn hard right or hard left and hit any kind of bump...big or small...it makes a semi-loud metal clanking noise from the undercarriage...under the drivers seat.
I thought it could be the tires rubbing but its not coming from the wheel well, its coming from underneath.
Any Ideas
Old 07-16-2003, 07:05 PM
evilcow's Avatar
Its the steering stops ( I dont know what they are really called ) There is a plastic bumper that looks like a acorn nut. Its on the inside of the wheel on the brake rotor dust shield. The bumper wears out causing metal to metal contact when the wheel is turned all the way. I just put some grease on it and its quiet for a while.
Old 07-16-2003, 07:07 PM
L33T35T 4Runner's Avatar
mine does the same
Bob refers to it as "mice"
Old 07-16-2003, 07:12 PM
Fink's Avatar
Would be obvious if I were to get under there and look at it while somebody turned the wheel or do I need some specific instructions on how to find it?
Thanks for the quick responses...any more ideas on it would be nice too!!
Thx. again
Old 07-16-2003, 07:59 PM
keisur's Avatar
Originally posted by 4x4Fink
Would be obvious if I were to get under there and look at it while somebody turned the wheel or do I need some specific instructions on how to find it?:
Just make sure the vehicle isn't moving when you climb under there.
Old 07-16-2003, 08:03 PM
KING's Avatar
I'd take a close look at the bushings.
Old 07-16-2003, 08:18 PM
Victor's Avatar
Put a big gob of grease on each steering stop. They are located on the front and back of the spindle on both sides of the truck. When you turn full lock they rub and make noise. There are supposed to be plastic covers onthem but they wear off very quickly.
Old 07-16-2003, 08:24 PM
Robinhood150's Avatar
Answers to all your questions:
https://www.yotatech.com/~corey/4runner_faq.htm
Old 07-17-2003, 07:41 AM
Fink's Avatar
You guys are a life saver, I crawled under there early this morning and had my bro jump up and down on the running boards and sure enough, those stops were rubbin like crazy...greased em up with some White Lithium Grease...NO MORE NOISE!
THIS BOARD ROCKS!
Thanks for the link RobinHood...I keep forgetting that Corey has that page...thanks guys!
Old 03-12-2004, 06:28 PM
jx94148's Avatar
They will start groaning again soon. Be prepared to grease them often or just don't turn the wheels that sharply unless its totally necessary.
Old 03-13-2004, 08:12 AM
KevyWevy's Avatar
hahaha old thread.
ripp96
07-25-2015 02:32 PM
yourrealdad
07-21-2015 11:13 AM
razorman8669
07-12-2015 12:13 PM
mlavery85
07-12-2015 10:33 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: Noise when turning
