| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Noise from suspension. Any ideas?
__________________
Greggie Poo *97 4runner SR5 4x4 sport *amsoil, flowmaster, air shocks, towhitch, yakima racks *Call her my "Huney" |
#2 (permalink) |
I have a similar noise. But I'm set on the fact that it is my brush guard causing it since I only have about 27k on it.
(Actually I don't even want to think it may be a suspension problem this soon)
__________________
'02 4Runner - '06 XRunner Breakdancing www.BadgeYourRide.com Check this out Multi-Touch Interaction Research http://mrl.nyu.edu/~jhan/ftirtouch/ Highest Xmax 6.5" subwoofer made Total Posts: 32,218 (75.35 posts per day) [/center] [/color] Still A Neon Last edited by 4-RUNNIN' FREAK; 07-09-2004 at 03:20 PM. |
#3 (permalink) |
Check on the bushings, that is where I have found a problem on my truck
__________________
Carsten -------------------------- 99 4runner SR5 4x4 5spd |
#4 (permalink) |
I have the fix for this.
1st you will need at least one friend and a 12pack of beer to fix this problem 2nd. Place said friend and beer into your 4x4 3rd. Drive out to your local 4x4 run. (drink beer) 4th. Find the biggest meanest mud hole at run. (drink more beer) 5th Drive threw mud hole (while drinking beer) several times at full throttle. (You must coat the entire undercarraige and all body pannels with mud for this fix to work.) 6th. Problem should now be fixed. but treatment may need to be re-applied at least once a month. If this does not fix your noisey suspension repeat steps 2 to 5. |
#5 (permalink) |
does that maethod realyl work 4Hummer
but i have had the same prob with my lift. i pin pointed my squeeking to the leaf pack. i hosed the pack down with WD-40 (i know i know , probably not the best solution) and the noise went down a lot. still squeeks but not as bad.
__________________
=Jason= 2001 Tacoma DC PreReunner SR5 (looks stock to me) S/C and some other crap |
#6 (permalink) |
Save yourself the gas. Just drink until your blind/deaf drunk. Problem solved!
__________________
'00 SR5, Desert Dune: 4" Deckplate, Amsoil TS-115, Bilsteins, Brembo rotors w/Performance Friction pads, Fiam Highway Blasters, Sylvania Silverstars, Hella Micro DE Fog Lights w/Hella Yellow Star Lamps - SOLD 1/24/09 '08 Sport, Salsa Red: Hella Optilux fogs, Silverstar Ultra Hi beams. Pending: Borla dual catback, CAI, shocks |
#7 (permalink) | |
Quote:
__________________
So I sold my '96 4Runner to get married...I was sad. BUT NOT ANY MORE! Check out my 1985 4Runner with 32,xxx miles! PoBoyTech.Net |
#8 (permalink) |
Yes that method works. Maybe its the Canadian Mud ???
Maybe The Mud sound deadens the noise ? Maybe the Mud lubes whatever parts are ratteling, Maybe the mud cakes whatever parts are loose ? I dunno but always works for me |
#9 (permalink) |
I have a slight squak from my sway bar bushing. Is WD 40 good enough? I really don't want to go to the dealer.
__________________
Jason B 4Runner Limited For Toyota/SUV Accessories, please visit www.burtmanindustries.com My 4Runner Website Email: jason@burtmanindustries.com Live Chat/Message Board: http://get.to/jasonforum AOL/AIM: JNB133 |
#10 (permalink) |
The rubber bushing is probably torn and is sliding out...so you are hitting metal on metal. WD40 will help for 5 mins of driving. The swaybar is like 4 botls...easy to drop out and replace the bushings.
__________________
#11 (permalink) |
how do remove the bushing on the eye of the shock near the control arm (I have one that is torn and need replacment). Will the shock decompress and be a pain to get back in place?
__________________
#12 (permalink) |
Do you have the cone bumpstops? On many 4runners the top of the spring will squeek where it is metal on metal. The cone bumpstops put a small rubber barrier between them. The bushings also will cause squeeking, even if they aren't bad. Mine would start to squeek a few months after lubing them. I finally got sick of pulling them off the grease them up and tapped grease fittings into the mounts. So far so good.
#13 (permalink) |
I had a squeaking noise like that and it turned out to be loose top shock nuts on the front suspension.
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 4Runner Suspension Help/Ideas | aquasport17 | 95.5-2004 Tacomas & 96-2002 4Runners | 16 | 01-05-2007 10:45 AM |
| Clicking noise from my 3.0, any ideas? | Fo by Fo | 86-95 Trucks & 4Runners | 0 | 10-03-2006 01:16 PM |
| Walbro Fuel Pump: strange noise...any ideas? | rimpainter.com | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 05-03-2006 06:34 PM |
| New To Forum - Looking for Suspension Ideas | 91ToyTrck | Newbie Tech Section | 35 | 04-11-2006 12:38 AM |
| 1st gen V8 4runner.. suspension ideas | deznoches | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 03-07-2004 03:04 PM |
