Noise with Amsoil Filter
This became apparent after I did the Deckplate and put in the Amsoil filter.
It’s an "intake whistle" that happens when the engine is under load at 2-3k RPM.
With the deckplate in place it is less noticeable but still present.
With the deckplate off and paper filter its almost totally gone.
I knew there would be more intake noise after the deckplate but it seems like it’s the filter that makes the most difference.
My Runner has almost 115k so I'm thinking it may be a clogged Cat.
Any others have this noise? Or is it normal?
That was one of the first things I checked after making sure no vacuum lines got disconnected. The edges were pretty oiley and kept slipping out of the corners on the first install. I wiped them down and they stayed. Also I stuck my hand through the deckplate (airbox off) and felt around to make sure it was making a seal.
Mine has also been doing that for the last 6 months or so.
At first I thought it was radio static and kept reaching for my radio that was turned off
crammit442
7
11-29-2017 12:30 PM
Iceman4193
08-28-2015 08:43 PM
