No Reverse lights after powerwashing...
Sponsor
i took the power washer to the underside of my 4runner and now i have no reverse lights nor licence plate lights. everthing else works fine both the window motor and break/turn/tail lights work fine. checked all fuses, all look good. can you guys think of any thing else to check?
bad grounds... check those... also you might want to try to get a circuit tester and run it on some of those circuits to try and figure out which one went bad
elictrical problems are a *****!!!! so with that said, good luck
beaux
beaux
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 08:05 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
