No reverse lights
No reverse lights
I have a 1997 Taco with 222k miles on it. The reverse lights quit working recently. I checked the fuses and they're ok. It's a 5 speed manual. I found a switch on the passenger side of the trans and checked it with a continuity tester with the key on and the shifter in reverse. There was no electricity to either wire. Anyone have any ideas?
1 Post
I have a problem with my back-up lights not working also. I haven't climbed under to check it out yet.
Not so sound like an a$$ but, i assume that when you are checking for voltage you have the key turned on?
In my case, I'm guessing that the trans switch is bad. It started to be intermittent. I could jiggle the shifter and it would flash on/off.
After clicking on the "tags" and "reverse" below I got some trouble shooting ideas.
Pull the wires off the switch, insert a wire connecting the two wires together, start the vehicle (it can be in neutral now) and look at your lights. This eliminates the switch. If they light then it's a bad switch OR what ever pushes on the switch inside isn't touching it any more. Next step is to pull the switch out and check continuity with a meter.
Really good info in this thread, including pictures. Part you need is 84210-12040 at toyotapartszone ($27.60).
https://www.yotatech.com/forums/f2/b...l-trans-92335/
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 08:05 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
