??? No oil pressure on gauge???
Old 02-17-2005, 05:59 PM
rj
rj's Avatar
??? No oil pressure on gauge??? (87 4runner)
I picked up an 87 4runner and rebuilt the 22re ( new bearings, pistons, rebuilt head) but I'm not showing any oil pressure on the gauge. How do I check to see if the problem is the pressure switch, the wiring or ??? Thanks, rj
Old 02-17-2005, 07:52 PM
SoCal4Running's Avatar
Well the pressure sender should be around the oil filter area on the engine block, its a black boot looking thing. You could remove it and install a temporary mechanical pressure guage just to make sure everything is ok mechanically.
Old 02-18-2005, 07:29 PM
rj
rj's Avatar
Thanks
Thanks for the impute. I am going to give that a try. I'm also going to disconnect the wire to it and check it for voltage with the key on. I'm told it should read out 12 volts if that end of things are working right. Thanks again, rj
Old 02-18-2005, 11:11 PM
bike4miles's Avatar
Yea, same thing just happened to me. How much is a new switch?
bigjstang
08-25-2021 12:41 AM
calderp
Engine Swaps
08-16-2016 05:15 PM
Jdgarrison
10-01-2015 05:22 PM
calderp
07-27-2015 09:58 AM
88yodabasket
07-13-2015 01:32 PM
Quick Reply: ??? No oil pressure on gauge???
