NO NO Ball Joints
NO NO Ball Joints
Sorry if I missed this in the countless threads, but is there a particular brand of ball joints (upper and lower) for '99 Taco 4x4 that anyone would recommend NOT using. I thought about going to Azone or ordering from Rock Auto. Thanks
Don't skimp on this component. You can skimp on many other components, even some chassis components, but not the LBJ's.
On the 3rd gen, the car is hanging from that ball joint, if it gets too loose, the ball pops out at the first opportunity.
On the 4th gen, the weight of the car is pressing the ball into the cup/base. It it gets loose, it will probably start making grinding noises, clunking noises. You could probably drive it like that for a while until an unlucky bounce of the wheel finally bounces the ball out of the cup.
X100, OEM or nothing.
Used the Moog or whatever off brand joints and they broke in 5-10k miles and maybe 1-2 years tops. Now my truck is still parked due to that and I need ~$1000 to fix it. Would have been much cheaper to get OEM to start with.
It's a design flaw in the sense that it does not account for complete idiots. Toyota fixed that. Just like they did with the floormats that now physically are clipped in.
Ball joints take 10+ years to wear out, and they don't fail unexpectedly if the proper LBJ inspection procedure is performed. It's no different than not checking that your driveshaft bolts are tight, and then having the driveshaft fall off and capapult the truck into the air.
I think that Toyota found that they needed fancy steel with either heat treatment or something like that in order to be able to stand up to the forces it is expected to see in operation. A better design would be one that allows Toyota to not use such fancy expensive steel and not have a premature failure. I think that that design is available, and it is the 4th gen design.
The fancy ones may take a long time to fail, I won't say 10 years because it is probably more about mileage, but as an automotive engineer, I can tell you that the more forgiving design is the better one.
You're right about the comparison to the drive shaft in the severity perhaps, but the occurrence is way lower the DS bolts are not maintenance items, the DS doesn't have to be replaced, it can be maintained in-situ). I'd actually argue that the severity is lower too, so the RPN for the DS failure is way lower than the LBJ. Maintenance is definitely a factor, but vehicles are designed to account for poor maintenance wherever possible. It's like a feature package; you can have one that you have to maintain or it will kill you, or you can have one that may break down with no maintenance, but it won't kill you.
The mats were not the cause of the acceleration problem that Toyota blamed on them. That was a legal and publicity scapegoat.
They most certainly are. It's right in that little maintenance booklet that came with every new 4Runner.
Bolts should be tightened every X miles. If someone drives a 4runner for 10+ years and never checks the bolts and they come loose, is that a design flaw?
The same with the "flawed" LBJ design. It's a tradeoff between reliability and something else. I'd suspect that LBJ hanging below the control arms is not as good for offroading as the old design.
Let's be honest here, the 4th gen's target demographic is very different than the demographic for a 4Runner in 1996 when it came out.
before mine failed I checked it repeatedly as I thought something was just not quite "right" with that side and I was getting a squeak from there sometimes.
Even checking and looking for an issue I could not tell the ball joint was bad, there was no play ect. A few days later, it failed.
So even regular maintenance can't find everything.
any chance worn ball joints could cause a pulsing or vibration when braking?
I did the tundra brake upgrade to my 97 4Runner and am having a hard time believing I warped the rotors. Everything was fine for a couple of years, but recently this developed. I do tow about 3500 pounds of John Deere or hardwood mulch from time to time.
I know how to check for worn ball joints. I pushed and pulled on the wheel as hard as I could. There was no slack.
Due to the design the ball is pulled into the opening of the socket and even if that opening is getting wider due to ware, it will still be tight until it pulls though.
Heck after it failed I pressed the thing back into the socket and it held just long enough for me to drive the truck into the driveway.
Per the Toyota service manual maximum play for ball joints is 0.02". You measure that with a dial gauge. Not eyeing it! You won't see even 100% wear, let alone 50% wear which would be 0.005" play.
And that's why your truck is on the ground now. Being a dilettante as far as maintenance is the the #1 cause of LBJ failures.
Can't remember how many times i did it, but the idea was to get them super heated to the point they start to fade. Then, making sure not to stop, let them cool down.
this might be hocus pocus, but i read it multiple places online, probably even here.
Besides, the brakes have been on there for at least 2 years, probably more like 3, and the problem just started.
Sorry for the temporary thread jack. I was just wondering if the vibration might be the ball joints. I really need to get the old girl in for a good once over.
