New tires wont fit :{
Old 08-13-2005, 01:08 PM
carose725's Avatar
Unhappy New tires wont fit :{
got my 33x10.50 bfg all terrains and found out the front tires wont go on because they will be rubbing right against the upper a arms. why have i not heard of anyone else with this problem. lots of people said they have the same setup. should i get wheels spacers
Old 08-13-2005, 01:29 PM
garrett1478's Avatar
what size wheels do you have?
carose725's Avatar
stock tacoma 15x7
Old 08-13-2005, 01:31 PM
i think you'll either need wheel spacers or new 15x8 wheels
Old 08-13-2005, 01:40 PM
carose725's Avatar
just couldnt believe a 10.50 would be to wide when lots of people use 11.50's. why must nothing work out. got the rears mounted they look great. guess ill order some 1.5'' wheels spacers.
Old 08-13-2005, 01:47 PM
Cebby's Avatar
How far are the tires into the a-arms? Maybe a 1/4" spacer would do the trick...
1 1/2" seems like overkill.
Old 08-13-2005, 02:01 PM
Intrepid's Avatar
Stock tires are 31x10.5 there really shouldn't be a problem, that is weird. Consider new rims with better backspacing too, if you like steelies you can pick up some chrome or black ones pretty cheap.
Old 08-13-2005, 03:54 PM
Silver_Truck's Avatar
Yup like Intrepid said I'm gueesing somethings screwed up with your backspacing...I'd go with as small of spacer as you can or sell the wheels and get new ones that will work
Old 08-15-2005, 10:52 AM
JGM
JGM's Avatar
That's funny - no one here suggested removing the upper a-arm, band sawing off a little, fill welding the hole, grinding it, painting it, replacing the ball joint, and then remounting the whole thing.
Just kidding. Check the backspacing. Are you sure those are stock wheels? Might even want to check that the tires are what they say they are.
Old 08-15-2005, 11:21 AM
99_Runner's Avatar
Flying91
45
04-11-2024 04:39 PM
BushPig
10-29-2022 06:26 AM
djpg2000
11-11-2020 04:56 AM
coffey50
07-28-2015 10:55 AM
Quick Reply: New tires wont fit :{
