new to Tacoma's have 3 questions!
Old 12-21-2011, 07:07 AM
Ilovemountains's Avatar
Question new to Tacoma's have 3 questions!
Im loving my double cab but have a couple questions that hopefully someone that has been around them longer than me can answer or point me in the right direction!
1: seat belt retractors, is there a way to add spring tension to them or do I just need to replace my front seat belts?
2: should my shift lever / transfer case lever be moving forward and backwards opposite of one annother every time I hit bumps or dips, Im wondering if my drive shaft slip yoke is bound up, there just seems to be a lot of movement in the levers!
3: Does anyone know what wire to cut that will disable the AC compressor from running when the defrost / defrost - floor setting is selected. 80% of the time I dont need to be running the compressor, I just like the this setting as it doesnt blow in my eyes!
Thanks again for everything and any help! ~Matt
Old 12-21-2011, 07:14 AM
Scratch #1 I found this after searching around some more!
http://www.4x4wire.com/toyota/minutemods/seatbelt/
Old 12-27-2011, 05:23 PM
eastsideyota's Avatar
Every yota has the seat belt issue, best thin to do is get some MasterCraft seats and some harnes's !
PureTacoma_Tundra
PureTacoma_Tundra
07-23-2015 11:20 AM
94yotaMI
07-21-2015 05:47 AM
94whiterunner
07-12-2015 07:15 PM
Poncho0206
07-10-2015 06:21 PM
Cplmike
07-08-2015 08:47 PM
Quick Reply: new to Tacoma's have 3 questions!
